Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 07-03-2011
tomperanteau's Avatar
Crotchety Old Member
tomperanteau is on a distinguished road
Norcold Refrigerator Conversion
I installed the Norcold kit the other day and it seems to work very well. When I keep things really close to the plate, they will stay frozen or freeze at about half the temperature setting on the dial.
Does anyone have any experience with the Norcold conversion kit and cruising?
Capt'n Tom Living Aboard 50/50
S/V Footprints
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006.
Hey, if I can't be sailing at least I can be here!
Old 07-13-2011
Here is a brief as to how I installed the unit:
Sailing Vessel Footprints » Blog Archive » Installing the Norcold Refrigeration Conversion Kit
S/V Footprints
Old 07-13-2011
jaredko is on a distinguished road
Looks good. Nice writeup. I have the same Norcold unit that was installed by the previous owner. I Believe it is about 6 years old and works great!
I did have an issue that started a few weeks ago where the compressor would run only sporadically and not work as well as it used to. Traced the problem to corrosion in the electrical connection between the cold plate thermister and the compressor. After redoing that connection, it's running like new again.
Old 07-13-2011
Thanks!
Good to hear that you've had a good experience with the Norcold. I've read mostly good reviews. Have you been able to freeze food close to the plate?
S/V Footprints
Old 07-19-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
How appreciated.marc is it working with the 10 cuft?Am planning on installing in a 7.5 any opions would be
Old 07-19-2011
First of all Norcold was probably pretty accurate by limiting the unit to six square foot. Although ours really cools the (10 sq ft) ice box, it has to run constantly. My box has a ridge all the way around about half way up that is for a shelf. I'm going to section off the lower half by installing a Plexiglas sheet with a door in it for that shelf. Then I can use the upper half as a cooler area for fruits and veggies. I also installed a small computer fan to circulate the air.
Advice would be to make sure that you have a ventilated area where you install the compressor. Mine doesn't get hot, but it does run warm and it needs to shed the heat. I installed it under the galley sink. I have a small fan on top of the compressor and another that brings cooler air from the bilge into that cabinet. The fans are so cheap (about $4) and they only use about a tenth of an amp to run, that they are worth it. Set aside about six hours for the entire job and plan things out before you cut or drill.
I know most of this is common sense and you probably already thought of it, but maybe it will help a bit. If I think of anything else I'll reply again.
S/V Footprints
Old 07-19-2011
MARC2012's Avatar
Thank you for data,will also install under sink.Looked can divide mine also.mar
Old 10-10-2011
Capt Len is on a distinguished road
Cold air
Tom, I added a length of flexible aluminum ducting to the fan This sucks air from bottom to top or end to end depending on on placement of cold plate.Mine runs all the time freezer is on but easy to make go with compressor only.Made a big difference.Capt Len on the Thane
Old 10-11-2011
MARC2012's Avatar
I ended up using a dometic unit & am pleased.Added 2 small computer fans under sink,usually run one.Only problem if overloaded will freeze up coils.marc
Old 10-15-2011
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
anyone else had experience with the Norcold units? The price is so much less than others it makes it very tempting...
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Norcold Conversion Kit tomperanteau Cruising & Liveaboard Forum 7 05-21-2011 10:33 AM
Refrigerator jacobitesc Beneteau 4 02-24-2009 03:17 PM
Warning on Norcold DE-0061R Refrigerator stuartbell Gear & Maintenance 0 09-30-2008 11:36 AM
Norcold vs isotherm fridge wchevron Gear & Maintenance 10 08-30-2008 09:32 PM
norcold seac Gear & Maintenance 0 06-09-2003 06:23 AM
