08-05-2011
Of course YOU CAN and with ALL the comforts of a motorhome or travel trailer. Much easier and more comfy if at a dock with electric, water, and even better if marina has Wifi and cable tv. If you can stand up in the Oday, it will help liveabiity.
WHATEVER your boat doesn't have you can add,-- 1. like shore power or just run electric thru hatch, 2. shower can be added, Oday 27 has a head, 3. Oday has room for 2 to 5 gallon water heater under many areas, but, how much hot water are you going to use ? Just heat water on stove.
4. Air Cond. buy portable unit with 5 inch exhaust hose, or window unit in companionway.
5. Heat. Easy with portable electric heater. 6. Mattress, very easy fix. 7. TV, now LCD.
8. Small fridge or freezer. If just you; you only sleep in on part of the boat and other births are freed up for whatever you like. 9. Running water, easy fix, my friend just did it on his 30 ft sailboat. Put new water bladder inside old rigid tank and got 12 volt water pump & clear hose & put cheap new faucets at kitchen and bathroom sink.
***People all over Florida are living on smaller and bigger boat than your 27 ftOday, and some without standing headroom---and anchored out and row into shore ! You'll be in hog heaven compared to them.
