Mold - Page 3 - SailNet Community
 2Likes
post #21 of 30 Old 10-30-2011
Thumbs up
White Vinegar Works. I also quit oiling the teak interior. I think the little mold buggars love the stuff.
Seaduction is offline
post #22 of 30 Old 11-02-2011
Schedule? Yeh RIGHT!
LookoutNW's Avatar
Originally Posted by neverknow View Post
Ozone will also kill mold/mildew. It will also eliminate odors. A complete cleaning like Rich suggested combined with a Ozone treatment for 24 hrs and your boat should be fine.
I may be wrong, but I think I read somewhere taht ozone is not good for rubber and plastics. Having this discussion before on another forum, we discussed it in depth.
It seems that OZONE generators for a 24 hour period are not too bad for the rubber and FRG but continued use is. Also 24 hours of OZONE saturation will kill all mold, mildew and pretty much all odors.
LookoutNW is offline
post #23 of 30 Old 11-02-2011
Yes, ozone rots rubber, plastics, greases, and more. Like bleach it is best used in moderation. And since it kills the crud, but doesn't remove it, the dead crud now becomes food for the next wave of live crud that comes in with fresh air. Still got to reach the inaccessible places to scrub them down.
hellosailor is offline
post #24 of 30 Old 11-02-2011
LookoutNW's Avatar
Agreed about the scrubbing. I got everywhere I could without removal of the FRG liner. Am hoping that the dehumidifier at 45% will keep it at bay tilll I can get out of Rainopolis. Air flow will help greatly when I get to warmer drier areas. I have modified my boat to keep the airflow maximized but need to be able to open it without the water flowing in...
post #25 of 30 Old 11-02-2011
neverknow's Avatar
Ozone is a good choice for deodorizing. of coarse use it sparingly.
A good choice might be to clean all surfaces with vinegar that you can reach and than open all floor boards and cabinet doors treat with ozone. That way you get the food for the next generation plus kill any spores that might be floating around. The ozone will deodorize too. We've even used it to get rid of fuel smells. Just some ideas.
neverknow is offline
post #26 of 30 Old 11-02-2011
I just cut up another oak pallet and run it thru the wood stove.
Capt Len is online now
post #27 of 30 Old 01-10-2012
RichH's Avatar
Here's an example of modern 'whitewash' (caustic) that can help control mold/mildew: 3M Marine Mildew Block Spray
Mildew/fungals, etc. easily propagate on 'acidic' surfaces; 'caustics' will prevent the spores from 'activating' 3M Marine Mildew Block Spray
The use of vinegar (a weak acid) although will briefly kill fungals because of relatively high 'acid', actually 'enhances' the site for future infection. The use of 'caustics' (whitewashing, etc.) has been the remedy for 'thousands of years'.
Most the plant pathologists and 'mycologists' Ive been associated with over the years would also from time to time recommend the use of TIN (stannic) compounds ... such as found in clear 'athletes foot remedies' to solve 'problem' re-infestations. I sometimes use a drug store product called "Tinacton" (athlete foot remedy) for my 'repetitive problem areas' on the boat.
RichH is online now
post #28 of 30 Old 01-13-2012
ardoin's Avatar
On the exterior, clorox and/or TSP works great.
On the interior, vinegar works okay, but the best is the old fashion Lysol in the brown bottle. You can find it at older grocery stores or older hardware stores. This is not the "lemon" or other junk sold by Lysol, you want the stuff that smells like iodine. Dilute it properly and then use it to wipe done the surfaces. Also works great on Frig seals. The stuff is great! That's why your grandmother used it! This is the best disinfectant.... a small dab on a fever blister will burn like hell, but you will be cured It is "liquid duct tape"
Cy
S/V Music
MASON 44
ardoin is offline
post #29 of 30 Old 01-13-2012
Any old timer knows the best possible remedy to mold and unnecessary filth is gramma's lye soap.As a child I helped to make this wonderful concoction.To find out more go to Grandma's Lye Soap: Good for Everything in the Home? .Be sure to sing along.It was banned for a while by religious rollers.
post #30 of 30 Old 01-29-2012
formerly posting as eryka
wingNwing's Avatar
We had some stubborn mold/staining that nothing seemed to work on, including the more expensive caustic sprays and scrubbing. Then just for kicks I tried baking soda + water and the black stuff washed away just like a bad infomercial. Only thing I could figure is that there's more than one strain of mold; some hate acid environments like vinegar & lemon oil; others hate basic environments (baking soda or ammonia). Found this site which seems to confirm my theory: How to Kill & Remove Mold with Bleach, Borax, Vinegar, Ammonia
tomperanteau likes this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
Mold in our poo SanDiegoChip Cruising & Liveaboard Forum 23 01-25-2012 02:36 PM
Black Mold gentryd Gear & Maintenance 27 07-29-2011 08:25 PM
mold inhibitors? dnf777 General Discussion (sailing related) 1 08-01-2010 10:54 AM
A smell of mold johnez General Discussion (sailing related) 1 08-20-2009 12:20 PM
Mold Removal usasophie Gear & Maintenance 19 01-13-2008 11:25 AM
