Condensation, itís raining inside! - Page 2 - SailNet Community
 6Likes
post #11 of 23 Old 11-11-2011
Crack open a hatch where you sleep
WDS123 is offline
post #12 of 23 Old 11-22-2011 Thread Starter
SanDiegoChip's Avatar
Soleus Air DP1-30-03
We just purchased the Soleus Air DP1-30-03 30 Pint Room Dehumidifier. Our boat is getting very wet at night from running the electric heater. We have an electric mattress pad with duel controls that helps a lot. But the boat does get cold and damp. While here in San Diego we will use this to keep the boat dry.
Let you know how this works out.
Chip
SanDiegoChip is offline
post #13 of 23 Old 11-26-2011
Swab
vega1860's Avatar
Experience
Originally Posted by SanDiegoChip View Post
Looks like from reading other posts (should have done that first I guess) that a dehumidifier or insulating is the only solution(s).
Chip
After three winters living aboard in the Pacific Northwest, I believe I can safely say that dehumidifiers and insulation will help but will not solve the problem. Ventilation and circulation of air and cooking and heating fuel that does not give off water vapor or at least minimizes it are the only permanent solutions to the condensation problem. Electric heat is best, propane is the worst.
If the boat is occupied, shoot for a complete exchange of air in the boat every hour or 15 CFM (Cubic Feet per Minute) per crew member (900 CF per hour) minimum. The typical 30 foot sailboat has about 1000 CF of volume IIRC. The more complete air exchange you can achieve the better. You will probably need to improve air flow (Cut holes in) lockers at least and probably install circulating fans to ensure dry storage spaces throughout the boat. Pay particular attention to the exhaust vents in your sleeping cabin and galley area and don't forget the lazarette.
A couple of four inch active exhaust vents with fans forward and a couple of passive vents aft may be enough but more will be better. Intake and exhaust vents should be as far apart as possible. An unoccupied boat may get away with one four inch solar exhaust vent forward and one passive vent of equal size aft.
OTOH, it is probably wiser to just sail to the tropics where you can simply open up everything and let the trades blow through
SVAuspicious likes this.
vega1860 is offline
post #14 of 23 Old 01-24-2012
If you are living aboard in San Diego we are extremely jealous of your condensation problems. The Pacific Northwest so far wins our award for creating "indoor rain" but Tonga is a close second. Our solution in the Northwest was a sizable dehumidifier, _after_ insulating with closed cell foam all areas next to the hull or deck not already insulated at the factory and installing an Espar forced air heater. In particular, the inside of the coaming (raised bulwark where the hull/deck joint is located) seemed to create rivers of water. At anchor in Tonga, with the relative humidity approaching 100%, we couldn't use a dehumidifier because it draws too much power and the air is 'way too hot anyway. We used a combination of Breeze Boosters, awnings, and open ports and hatches, plus cabin fans (especially in the V-berth peak). I recommend reading The Warm Dry Boat as a sort of primer for figuring out what your particular boat needs.
unomio is offline
post #15 of 23 Old 01-24-2012 Thread Starter
Update
We placed the unit in the head for now. It is a bit larger than we thought. We set the humidity level to 40. It is recommended for the room humidity to be between 30-50. We left it on over night and we used the heater. We got up as usual for work only this time the boat was dry!
Sometimes we up it to 60-70 as we like some moisture and the boat still stays dry.
We let this run at night to keep the boat from getting too wet. We use an electric heater with a thermastat to keep the boat from being too cold at night.
The boat still will get chilly but not real cold.
This hatch is over the bed. When this Sky Shade is closed it still stays mostly dry.
This one is in our head and is closed but stays dray any way.
Our port holes and windows stay dray and the boat never gets stuffy as the air moves about.
On our 36' sail boat we alwasy have the fan on low when we have the unit runing. The fan has three settings. Unless we are cooking spaghetti or something with bowling water.
For us it has been well worth it.
Chip
post #16 of 23 Old 01-25-2012
40 years of living aboard full time in BC has convinced me that the 1 1/2 inches of spray foam insulation is the only reasonable solution here. My boat is warm and dry, thanks to the insulation and the wood stove. If I turn my salt shaker upside down, it will completely empty itself . I have zero condensation problems. The ceramic bead insulating paint addative from High Tech sales in Florida, is a simple solution which may work in sunny San Diego.
The more insulation the more comfort, period.
TBTF as a paint addative for mold prevention is available in some paint stores. If it is not available in the US , you could get it in Mexico.
I've heard a painting with a borax solution also works , tho I've never tried it.
Brent Swain is offline
post #17 of 23 Old 01-25-2012 Thread Starter
Yes, doing something inside the lockers would be nice. We have been thinking of options. Spray foam seems the best way as gluing closed cell foam in there would be difficult.
We will be using AC in the future in Mexico so moisture is not going to be an issue but keeping out the heat will.
Chip
post #18 of 23 Old 01-25-2012
Maine Sail's Avatar
What do others do about this issue?
This is our first winter aboard our 36’ sail boat. We have an Islander Freeport B plan. That means our stateroom is forward of the salon with a pullman queen birth to port. The head is forward where the V birth would be.
We use an electric heater with a thermostat which sits across from the bed between two hanging lockers. We also have an electric matress pad that heats up from the feet up keeping cooler at the top by your head. Two controls which is nice, wife and I have different tempetures. So far all is well.
The head door we leave open.
The salon door we leave closed.
The stateroom and head get some condensation. The head gets more as there are more cabinets that get the condensation. The cabinets are under the side decks. It gets bad enough in the cabinets it drips.
We have tried closing the head door and opening a hatch in the head to create the same temperature as the outside. No help as it still gets condensation. Also it is a cold trip to the toilet
We are going to try another heater in the head this weekend.
Would a dehumidifier work?
What works??
Insulating the cabinets with closed cell foam may work but that is not a quick fix, oh yea we are looking for a quick fix
Never mind the red box it was for another issue, it is where the heater goes though
Thanks,
Chip
Keep your bilge bone dry, that can help, but you give off moisture too. Electric heaters can't really "dry" the air but provide drier air than say many LPG etc. systems. If you have to compete with a bilge full of moisture and two adults you're going to get some condensation. Think air turnover....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 23 Old 01-25-2012
Insulation and vapor bariers aside, in a nutshell you need to start with 2 simple things.
1. Heat the interior warm enough so moisture will evaporate off the walls and "float around" in the air. The walls will appear dry but the moisture will still be in the air. Hopefully your heaters will have fans to move the air around, and hopefully they are safe. (I personally dislike electric heaters on a boat for safety reasons).
2. Use a dehumidifier to capture that "floating moisture" - read the instructions that come with the DH as to what happens when the interior is not warm enough.
Then save up for a diesel hot air furnace.
Sea Diamond is offline
post #20 of 23 Old 01-26-2012
Mermaid Hunter
SVAuspicious's Avatar
Ventilation is key. I concur with the earlier recommendation to get a copy of and read "The Warm Dry Boat" by Roger McAfee.
In the near term, take the doors off your lockers to increase ventilation of the lockers and even out the temperature differential.
SVAuspicious is offline
It''s Raining Inside My Boat sadie14 General Discussion (sailing related) 14 12-13-2011 02:44 PM
Condensation Sensation Skipper Joe Gear & Maintenance 2 09-30-2009 11:42 PM
It's raining greenish yellow BBs skyellab Racing 7 07-31-2008 06:38 AM
Voyage of s/v Whisper's Echo: Still Raining @ Sail Blogs NewsReader News Feeds 0 04-08-2006 10:16 AM
