Condensation, itís raining inside! - Page 3 - SailNet Community
 6Likes
post #21 of 23 Old 01-26-2012
pdqaltair's Avatar
A nice, simple explaination.
Originally Posted by Sea Diamond View Post
Insulation and vapor bariers aside, in a nutshell you need to start with 2 simple things.
1. Heat the interior warm enough so moisture will evaporate off the walls and "float around" in the air. The walls will appear dry but the moisture will still be in the air. Hopefully your heaters will have fans to move the air around, and hopefully they are safe. (I personally dislike electric heaters on a boat for safety reasons).
2. Use a dehumidifier to capture that "floating moisture" - read the instructions that come with the DH as to what happens when the interior is not warm enough.
Then save up for a diesel hot air furnace.
I'll add to it:
3. Ventilation also "dries" the air if heat is in use; the colder exterior air is always drier because it is cold and cold air holds far less moisture. Houses generally ventilate through leakage; boats are much tighter and much smaller. The clothes drier and bathroom fans can also pull a lot of humid air out of a house.
4. Moisture comes from many sources, but the main source for live aboards is exhalation, perhaps 1/2 gallon per person per day. Add to that cooking, showers, and wet bilges.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #22 of 23 Old 11-07-2015
Re: Condensation, itís raining inside!
PDQ! Tell us what you do!
Bronwyn is offline
post #23 of 23 Old 11-07-2015
pdqaltair's Avatar
Read the whole thread (post 4).
* Insulate + storm windows
* Minimize moisture. Add a shower fan or shower ashore. Dry towels outside.
* Heat the whole boat
* Dehumidify, if needed
* Dry bilges
It''s Raining Inside My Boat sadie14 General Discussion (sailing related) 14 12-13-2011 02:44 PM
Condensation Sensation Skipper Joe Gear & Maintenance 2 09-30-2009 11:42 PM
It's raining greenish yellow BBs skyellab Racing 7 07-31-2008 06:38 AM
Voyage of s/v Whisper's Echo: Still Raining @ Sail Blogs NewsReader News Feeds 0 04-08-2006 10:16 AM
