Full or fin keel? - Page 28 - SailNet Community
 247Likes
post #271 of 847 Old 04-04-2012
mitiempo's Avatar
Re: Full or fin keel?
The Cigale is less extreme than an open boat and has more amenities than a Pogo. I'd take one any day.
Brian
mitiempo is offline
post #272 of 847 Old 04-04-2012
Regarding the cruising Pogo it is a much bigger boat. We will see when they finish the first Pogo 50. That one has a much better interior, doors and all
Regarding boat sailing characteristics they are not much different, they have the same kind of hull even if the Pogo has a bit more beam, but the weight is not much different considering that the Cigale 16 is 2 ft bigger.
The Pogo 50 weights 8900kg and the cigale 16 10750kg. The Pogo has more sail but not much: 150m2 for 141m2.
All in all you are right, the Pogo is faster and more close to an open boat...but not much
The Cigale has the advantage of the stronger aluminium hull but the Pogo has an huge advantage in what regards the cruising grounds and capacity to get shelter near the coast. Its draft with the keel up is only 1.5m. With the keel down the tracking upwind should be great with a 3.5m draft keel.
Saying that I would also prefer the Cigale, but that is just because I am getting old But hei, give me a Pogo 50 and I will be happy too.
post #273 of 847 Old 04-04-2012
DO we really need keel's at all???
Just joking. But..
Have anyone seen this???
CHARTER BOAT LOSES KEEL: And No One Noticed
Somekindofaviking is offline
post #274 of 847 Old 04-04-2012
mitiempo's Avatar
Yes, i saw that a while ago. It says a lot for form stability.
But no, keels aren't required.
Brian
mitiempo is offline
post #275 of 847 Old 04-05-2012
Makes me think that those "dreaded bendytoys" can't be so bad at all...
Of curse I would not want to loose the keel. (If it was there to begin with)
But it is kind of reassuring to know, that others have done it without sinking their boat...
Maybe it was just luck, or some kind of production error..
But.....
Seriously...
Boats, that can handle this kind of abuse...
Should be able to cross some big oceans...
For those of you that are a little allergic to German, press mute...
(No.. I am not from Germany..)
But..
I am one of those willing to loose some comfort, to gain some speed..
post #276 of 847 Old 04-05-2012
Ilenart's Avatar
Yesterday I finally got around to reading this post (guess I was wondering how you could talk about this subject for more than 200 posts, now I know )
Anyway here is my two cents worth. For five years I owned a full length keel Roberts 45 Classic. Below is the design.
Photobucket
Two year ago I sold he Roberts and brought a fin keeled UFO 34, as per below:
Photobucket
I have compared the two yachts extensively in a wide range of wind and sea conditions, including tacking angles, upwind / downwind / reaching performance, effect of waves, etc using the same navigation software / GPS setup.
As would be expected, the UFO 34 certainly had better upwind performance. However the truth is the UFO 34 has better sailing performance in ALL conditions, be it upwind, downwind reaching whatever. I've yet to find conditions where the UFO 34 does not perform better than the Roberts 45.
Some people will probably suggest that this is an unfair comparison comparing a heavy cruising ketch with a medium cruiser / racer. However you also need to remember that the Roberts 45 is more than 10ft longer than the UFO 34 and the larger yacht still loses in a sailing competition. (note 45ft excluded the bowsprit and davits, overall length was closer to 55ft.)
I would also agree with others that point out that the keel type is one of a number of factors that go into sailing ability. However most full length keel boats also tend to be heavy boats with similar charateristics to the Roberts.
Like others have said, there is a reason why Hallberg Rassy, Malo and other builders have progressed from full length to fin keels, as the benefits outweigh the negatives.
Ilenart
Faster and mitiempo like this.
Ilenart is offline
post #277 of 847 Old 04-05-2012
casey1999's Avatar
Photobucket
Photobucket
Ilenart
Why did you trade to a smaller boat? How do the cruising speeds compare under sail?
casey1999 is offline
post #278 of 847 Old 04-05-2012
blt2ski's Avatar
Casey,
Suggest you look at the RED highlighted part Ilenart's post near the bottom, he answers the Where the smaller lighter boat is better and worst than the larger heavier boat. OR, should I tell you that the larger heavier boat does NOT perform better in ANY condition vs the smaller one!
Marty
Photobucket
Photobucket
Ilenart
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #279 of 847 Old 04-05-2012
casey1999's Avatar
Originally Posted by blt2ski View Post
Casey,
Marty
I was looking for the cruising speeds in Knots for each vessel.... Seeing one should have a higher hull speed the comparisons would be interesting...
In any case, glad to hear Ilenart likes his ufo 34 as my boat is nearly identical....
post #280 of 847 Old 04-05-2012
blt2ski's Avatar
Okay, got it!
The actual speed numbers would be interesting. BUT, probably also like my comparison to some smaller and about the same disp earlier, it may not be as drastic, but still better due to typically a lot more SA/disp ratio on typical fin keels vs full keels.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Tags
boat buying , newbee advice
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 03:52 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 12:51 PM
4 ft draft, full keel, 30' and over? birdlives Boat Review and Purchase Forum 6 09-18-2010 12:00 AM
Older Full Keel boats JerryO39 General Discussion (sailing related) 30 06-09-2010 10:06 AM
Bristol 32'' full keel johnblsc Boat Review and Purchase Forum 2 12-13-2002 06:37 AM
