Full or fin keel? - Page 43 - SailNet Community
 247Likes
post #421 of 847 Old 05-13-2012
mitiempo's Avatar
Re: Full or fin keel?
You can touch bottom with a 9' draft or a 2' draft - the trick is to avoid it with any boat.
Brian
mitiempo is offline
post #422 of 847 Old 05-13-2012
Senior Cruiser
sea_hunter's Avatar
For those that state with utmost authority that one keel be better for the Florida shoals than the next; nonsense. If you continue to ground, please learn to check your charts and tide tables. If the ground is ever shifting why is it that we don't hear of freighters and other naval ships constantly aground in the southern states? Keel length is relative. A 6 foot draft on a 50 foot boat that IS a shallow draft design. My issue with fin keels is the inherent structural incongruities with an increased (and increasing) possibility of catastrophic failure. A cursory search on Google of "boat looses keel" is disturbing to say the least. Keel type is argumentativly as personal a preference as whether or not you have a ketch, sloop or power boat. If you still keep grounding, perhaps some training wheels might be in order.
mitiempo likes this.
sea_hunter is offline
post #423 of 847 Old 05-13-2012
Originally Posted by sea_hunter View Post
For those that state with utmost authority that one keel be better for the Florida shoals than the next; nonsense. If you continue to ground, please learn to check your charts and tide tables. If the ground is ever shifting why is it that we don't hear of freighters and other naval ships constantly aground in the southern states? Keel length is relative. A 6 foot draft on a 50 foot boat that IS a shallow draft design. My issue with fin keels is the inherent structural incongruities with an increased (and increasing) possibility of catastrophic failure. A cursory search on Google of "boat looses keel" is disturbing to say the least. .....
Not to mention big sail yachts from whom a 3.00m draft is shoal draft. You a smaller boat or a boat that can raise the keel you can go to more places and be more nearer from the beach, or on the beach but that's all.
Regarding losing the keel if you pay attention those boats are very high profile racers that have been built to be as light as possible and that are to be used with regular inspection checks to all stressful parts of the hull. There are no cruisers losing keels, not even big mass production cruisers at least to in any meaningful number.
There are cases where boats are thrown to the coast by storms or bad navigation and even so the fin keels survived. You have the recent case of that Sydney another one with a Mini class racer that was put again in the water and sustained not only the efforts on the way to the beach but also the efforts when the boat was pulled again (by boats) to the sea again and you have for instance these cases:
post #424 of 847 Old 05-13-2012
wolfenzee's Avatar
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
I live in the Pacific North West with over 10ft tidal change, I draw 5' so theoretically anything that the chart lists being wet at mean low is navigable at high tide....theoretically. I grew up on the Chesapeake, 3' tidal change and if you ran aground it was sand or mud...up here it is rock so the idea of running aground is unnerving (ironically the only time I have run aground here was in the mouth of the Frazier river, sand) when I was in BC even though I knew the charts were in meters...I treated them as feet.
Joshua Slochum said "Anyone who says they have never run aground has never been anywhere (or is lieing)".
jrd22 likes this.
wolfenzee is offline
post #425 of 847 Old 05-14-2012
Senior Cruiser
sea_hunter's Avatar
Paulo, while I enjoyed your video posts, and there appears to be little or no damage to the keels or the hull keel joint, it requires a experience eye to determine how bad the damage. Just ask the crew of the Cynthia Woods.
Wolfenzee, having spent 35+ years boating the PNW, some of it commercial fishing, some of it cruising throughout many rivers and inlets of BC, Alaska and Washington including the Fraser, a river that moves 20 million tons of sediment every year. Keeping this in mind, if you're outside the channel markers on any arm of the Fraser River Delta you're on your own.
Your comment
This should have actually been beneficial as 1 meter is about 3 feet. If your were siting in 5 meters of water, thinking it was 5 feet, it would be closer to 15 feet; so I really don't understand where you're going with this thread, other than sinking deeper into the sand.
By the by, the quote you attribute to Slocum wasn't actually by him and the fact that his circumnavigation took place in 1909, effectively removes him from the argument with today's availability of modern charts, GPS and the like. (I have to add that Slocum disappeared in November 1909 while aboard his boat, the Spray) While I applaud your attempt of rationalizing incompetence, it's a ludicrous idea that in these modern times with the availability of updated charts and depth sounders that "you're not a boater till you've grounded out". Perhaps this argument should be employed in the defense of the Costa Concordia's captain.
At high tide, fish eat ants; at low tide, ants eat fish. ~ Thai saying.
post #426 of 847 Old 05-14-2012
This one I saw by myself. This guy run on rocks doing over 6K. Brand new boat
The lead keel was bent but not the slightest damage on the outside joint or the interior frame work that distributes the loads or on the attachment points.
post #427 of 847 Old 05-14-2012
PCP :
With a long-keeled ship, the keel will not bend like that.
And as for "not the slightest damage", well, for me, read "not the slightest visible damage".
I wonder how it would slam in a big forward sea?
Rockter is offline
post #428 of 847 Old 05-14-2012
Originally Posted by Rockter View Post
PCP :
No, I had talked with the guys from the shipyard. No damage at all except a bent lead keel.
You have to decide what is being discussed The discussion was about keels falling off. Regarding the bent keel this is an all lead keel on a fast cruiser-racer. Keels on medium weight cruisers like the ones on the movies are stronger.
Regarding what would have happen with a full keeler hitting at full speed rocks well I guess it would have depended on the boat. The keel would not bent but the damages sustained on the keel and hull could be far more expensive to repair than a piece of bent lead. Jeff has explained already that quite well on a post on this thread.
post #429 of 847 Old 05-14-2012
Sail the boat you like and fits your mission. This isn't a fact based argument thread, its opinion. As far as safety and efficiency, the argument about 'fin' vs. full was over and the door nailed shut with Mr. Perry's Valiant 40 and the Cal 40. Boats of BOTH types (full and fin keel) sail successfully pretty much anywhere people sail. Sail what you want and have fun doing it, but don't make an argument rationalizing what millions safe ocean miles has proven to work very very well. So much so that full keel boats are becoming rare.
puddinlegs is offline
post #430 of 847 Old 05-14-2012
leave my member alone
Send a message via AIM to Chadfunk48
The seafloor is ever shifting... that's not an "if" it can be seen on anyones depthsounder from one year to the next. Because freighters and navel ships use channels that are regularly dredged and monitored for depth.
Life is to short to be crabby. Go sailing!
Chadfunk48 is offline
Tags
boat buying , newbee advice
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 02:52 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 11:51 AM
4 ft draft, full keel, 30' and over? birdlives Boat Review and Purchase Forum 6 09-17-2010 11:00 PM
Older Full Keel boats JerryO39 General Discussion (sailing related) 30 06-09-2010 09:06 AM
Bristol 32'' full keel johnblsc Boat Review and Purchase Forum 2 12-13-2002 05:37 AM
