- Quick Menu
239Likes
12-28-2012
Re: Full or fin keel?
Wolf,
Curious, is your B/D only using the "lead" in you keel? if so, you probably have a higher % than that, as one "should" IMHO include the rest of the keel as ballast per say. A swag would then be 4500lbs/15K = 30%. As you really have what is a precursor to todays T keels, but do to materials and knowledge of some material strength, many things were designs heavier than need be. With what is probably a 5'long, 6"wide, 1'high chunk of lead at the bottom of your keel, it behaves like a heavier fin keel from a stability point of view.
my 01 on the subject.
Marty
She drives me boat,
I drives me dinghy!
12-28-2012
Originally Posted by wolfenzee
My 30' full keel has a B/D ratio of about 25% (3800lb ballast/15,000 disp)
That is pretty low for a full keel and points to a tender boat. If you search and look at several full keelers you would see that the average is over 30%. They need more ballast because for the same dimension full keels had normally less draft.
what is the draft of your boat?
12-28-2012
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
Originally Posted by blt2ski
My previous generation by 3 or 4 Jeanneau, has 2400 to 6500 lbs of boat. With a 5.5' draft.
At the end of the day, if the boat works for your purpose, keel design and where the ballast is set at works, away you go! enjoy your boat! I'll still take my Jeanneau over an equal Catalina with a lead keel, I may heel a bit more, but I am faster in all but light winds!
Marty
A light weight disp fin keel will do better than my boat in light air (<5kt), but not by much, alot of heavy disp full keels can't get out of their own way in light air, my boat has always surprised me in light air. It doesn't take much for me to get to hull speed, 10kt wind w/main and working jib = 6.5kt. My boat starts to excel over the lighter fin keels as the wind kicks up, and when things get dicey I would have anything else. My "obsolete/antiquated" rig works differently and behaves differently with performance weeks over the years is quite satisfying, aside from performance, she has a style and grace that just doesn't happen in production boats. I respect "to each his own" as should everyone.
12-28-2012
Bear in mind the buoyancy of a wide, full length keel.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
12-29-2012
My draft is 5' original ballast was 3200lb then 800 more was added totaling 4000, disp is about 15,000 (27%) still a little tender. Original design called for 13,200 w/3200 ballast (24%), but construction method ended up with a much heavier boat (still riding on design water line). It doesn't take much to get the boat over to 30degree heel, but once there it doesn't want to go any further (builder named the boat "Roll N' Go"), I know, I've tried, it's better to discover your boats limits before they get shown to you.
12-29-2012
Get one of these (or similar)....
You can't beat a long keel in these conditions.
01-03-2013
Re: German Yacht Magazine Article on Full vs. Fin Keel
Sure, you are right as usual
Makes sense as I only post when you are wrong.
The Jeanneau 30 has a B/D ratio of only 24%, the Jeanneau 33i has 32%
Most of these boats have or more draft or more modern and efficient keels that will make the difference in RM even more meaningful. To my knowledge there are no other 29/33ft as tender in the market as the Jeanneau 30.
B/D can only be used as a measure of stiffness when the hulls are identical and the weight is proportional the same. Clearly not the case here.
And what do we care about the other boats you listed? They have nothing to do with the discussion at hand.
And clearly RM only is a measure of stiffness when the RM diagrams are identical shape. Clearly not the case here.
I can't imagine why you bring up the 33, when this test compares 30 foot and under boats.
So basically, your discussion of B/D has no meaning here. I suggest you learn a bit about what stiffness means.
Bryce
01-03-2013
This was what was in question, this statement of yours:
Originally Posted by BryceGTX
Whoa.. a 30i is a particularly tender boat??? Clearly it is representative of a stiff production boat of the 30 foot size compared to the others.
Sorry.. you are wrong.
Bryce
The Jeanneau 30 has a B/D ratio of only 24%, the Jeanneau 33i has 32%, the Benetau First 30 has 29%, Dehler 29, 37%, Dufour 335 has 28%, Hanse 325 has 29%, A31 has 40%, the Elan 310 has 28%, Delphia 31 has 33%, Benteau Oceanis 25%, Bavaria 33 26%.
and you say now about that:
... I suggest you learn a bit about what stiffness means.
Bryce
Here you have the hull of the 30i:
Here you have the hull of the 33i:
The Displ/lenght ratio is: 162.7 to 169.6
The very small difference in displacement/length has to do more with the much bigger B/D of the 33i then with any difference in the hull type or keel type. Both boats are even designed by the same NA.
Clearly it is the same kind of hull, the same kind of keel, the same kind of Displ/Lenght ratio.
How difficult is the check the data before posting?
Hull construction does have alot to do with it. My hull is 1" thick mahagony strip plank, glued and top nailed with 3" nails, screwed onto 2x3" double frames (which are bolted together with 3/8" through bolts) and 1/4" ceiling....to finish it off the builder also covered the boat with two layers of fiberglass. The weight is distributed alot more evenly.
B/D ratio by itself doesn't mean alot whole lot, it is simply "An indication of a boats stiffness or it's ability to resist heeling", some boats actually perform better when heeled (mine does best at 25-30 degrees and it doesn't take much to get it there) and some of weekend cruisers get nervous if there boat goes beyond 10 degrees so there are boats designed accordingly.
The height of the mast, sail area and beam all are necessary calculations here is a performance calculator for cruising boats: SloopIT - Boat performance calculator
01-03-2013
So I should check a 33 is bigger than a 30???? Who cares?
They also chose for the comparison a particularly tender boat. If they had chosen the slightly bigger jeanneau 33i (much more stiff) I am sure the results would be different, not regarding comfort but speed.
The 25/26 issue of the German bi-weekly Yacht magazine has a very interesting article comparing a full keel (Vindö 40, 31ft, 1971), a moderate fin keel with skeg (Hallberg Rassy 29, 1981) and a modern fin keel boat (Sun Odyssey 30i, 2008).
Paulo.. given that the three boats in question were 31ft, 29 ft and 30 foot.. why in the world would you suggest than anyone would compare these boats to a 33?
Who cares that a 33 is more stiff or faster or whatever.. clearly it is in a different class...
Bryce
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
