Full or fin keel? - Page 82 - SailNet Community
 247Likes
post #811 of 847 Old 05-18-2013
grumpy old man
Re: Full or fin keel?
Don't see anything about CFD Paulo. How are you certain CFD was used? Can you provide a CFD study that has been published? I'd like to see that for my own education. I wouldn't make the automatic assumption that CFD is being used for every new keel you see from a major design office.
I understand the theory behind the tandem keel. As I said it is far from a new keel geometry. I don't doubt that it works, to some degree. But the real appeal may be more for marketing. Seems like you bought it.
Bob's Blog ....
bobperry is offline
post #812 of 847 Old 05-18-2013
I don't know of any major NA cabinet that does not use CFD in what regards hull, keel and rudder design.
I am not defending tandem keels against other solutions for swallow draft. I am only saying that it is still a contemporary solution in a sense that it continues to be a valuable option.
Personally I think that the best contemporary solution for a shallow draft are swinging keels. Those are the only ones that manage the miracle of offering a similar tracking upwind, a slightly lower weight for the same RM at the cost of a slightly bigger draft without having a big intrusion on the interior habitability. The only real problem is that they increase the boat price and need some maintenance.
post #813 of 847 Old 05-18-2013
grumpy old man
Paulo:
I'll have to defer to your superior knowledge in the area of yacht design and yacht design offices. I have not been at this very long. You obviosly have far more depth and bredth to your design office experience than I have. I can only hope to one day have as much knowledge of yacht design as you think you have.
Here are a couple of small projects of mine. I'd love to see some of yours.
I am in full agreement with you that swing keels are the optimal solution for shoal draft. I am very lucky in that I live where the water is very deep so shoal draft is not a concern of mine. Although I have designed one or two boats where draft was a major consideration.
antigua%20ft.jpg   Feral FT10m_003.jpg   ICON with Code zero.jpg   Ican in SF 2.jpg
Bob's Blog ....
bobperry is offline
post #814 of 847 Old 05-18-2013
Paulo:
I don'y understand your attitude. I am not a yacht designer and I never have pretended to be. That does not make less true that today all major NA cabinets use CFD in what regards designing hulls, keels or rudders. Many advertise so on their web sites and others even publish some computer prints of the studies. It is only a complex computer program that accesses the efficiency of what has been drawn and contributes to improve the design.
post #815 of 847 Old 05-18-2013
grumpy old man
Oh come on Paulo.
Me? An attitude? I'm not sure what you mean.
Bob's Blog ....
bobperry is offline
post #816 of 847 Old 05-20-2013
Moderator
Jeff_H's Avatar
Paulo, I am not sure that your assumptions are right. I attend a lot of presentations on the development of yacht design software and how it is being used. Clearly CFD is out there and being used on specfic projects by the high visibility high performance shops. But for the most part, what seems to be way more common in design offices are a battery of VPP's (velocity prediction programs) that are based on historical data and prior CFD and towing tank studies. These VPP's are pretty good but they do not analyze down to a level of detail which would validate the performance of a particular choice of keel profile, keel section, or keel layout.
The better of these programs produce quasi CFD data and the kinds of graphics that replicate what you would expect out of a full blown CFD analysis, but these programs do not appear to be at the fine grain level that would be needed to analyze whether a specific tandem keel worked effectively or not.
This is not to say that RANS and CFD analysis is never performed. I think that really high budget projects get that level of attention. Farr's office showed amazing graphics from their analysis of the new Volvo boats.
I am talking with Quantum about doing a paper exploring the trade off between sail area and sail shaping for cruising boats (i.e. more powerful sections vs. larger sail area) and in the course of the preliminary conversation, it was suggested that ideally we should use the VPP for a specific design, including the drag, leeway, and stability characteristics of a real hull and rig.
The designer at Quantum and I spoke to one of the partners at Farr about the likelihood of getting basic data on one of thier newer production designs, and while it was clear that Farr ran moderately sophisticated performance analysis on all of their designs, it was not clear that it was run on a fine grained enough level to allow a precise enough computer simulation for the sail study.
As recently as only two years ago, there was a paper presented on a study to validate a CFD analysis of flows around a keel. It was one of the first times that they were able to instriment a full sized keel in action to measure the points at which laminar flow became turbulent. They found that there was almost no steady state laminar flow, and that the flow even in calm water was discontinuous, shredding in much the same way that spinnakers have discontinuous flow. It largely invalidated the CFD which assumed way more continuous flow than existed, and it was only once factors were added for discountinuity that the CFD could be validated.
So, while I do not want to talk for Bob, and I do not want to be dimissive of what you are saying, my sense of this is that CFD, especially for keels is still in its infancy, and that while better design firms have access to CFD for their higher budget projects, it is not in general use and perhaps fine level analysis not accessible enough to acertain that a tandem keel really does work as advertised.
Respectfully,
Jeff_H is online now
post #817 of 847 Old 05-20-2013
Best Looking MALE Mod
Cruisingdad's Avatar
I hope this is not considered a hijack, but since i know nothing about sailing or cruising, just wanted to ask: why would anyone choose a racer for a cruiser?
Just askin'.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
The Following 2 Users Say Thank You to Cruisingdad For This Useful Post:
Minnesail (05-20-2013), RickWestlake (05-22-2013)
post #818 of 847 Old 05-20-2013
Respectfully,
I did not said all NA, I had said major NA firms use CFD to help designing boats. As you have pointed out Farr use it as other major Na firms and even some minor ones. Look at these computer printouts from Ker. The first one refers to the final hull for the Sydney GTS 43, designed with the help of CFD, the second one is a beautiful study on a keel and ruder flow.
You can read on the site about the CFD they use (Numeca).
http://www.kerdesign.com/Technology.html
Some advertise that on their site, others not. Have a look at Berret/Racoupeu (the designers of Allures among other sailingboats):
As part of our research and development efforts, we made the deliberate choice, some time ago, to incorporate totally digital calculation and analysis procedures.
As genuine decision-making tools, these different digital simulation programs enable us to confirm our design ideas in a flexible and efficient manner and at an acceptable price. In contrast, to achieve comparable accuracy, experimental processes such as towing tank tests, wind tunnel testing or mechanical trials are significantly more laborious and costly, less “state-of-the-art” and ill-suited to systematic use.
Digital tools enable us to optimise hull shapes, sail plans, appendages such as keels, and rudders for example, and to predict their performance based on outdoor conditions such as the wind, its strength, the direction its blowing from and the state of the sea. All of our yachts systematically undergo these simulation steps to guarantee optimized performance and handling. Structure is high on the agenda too, using finite element method (FEM) calculations. This equipment is systematically incorporated into our design procedure, for all of our creations. Over the years, thanks to our experience, we've developed and optimized their use.
http://www.berret-racoupeau.com/recherche_uk.php
post #819 of 847 Old 05-20-2013
Once known as Hartley18
Classic30's Avatar
Dock
I am talking with Quantum about doing a paper exploring the trade off between sail area and sail shaping for cruising boats (i.e. more powerful sections vs. larger sail area)....
Having recently forked out $$ for a headsail that after 4 re-cuts we can't get driving properly - that's got MY interest, Jeff!
Care to add anything else - or start a separate thread on this??
Cheers, C
Classic30 is offline
post #820 of 847 Old 05-20-2013
grumpy old man
Paulo those are lovely photos you downloaded from the internet. I'm not sure what they have to do with the tandem keel though. I see no mention of the tandem keel in any of that downloaded material.
I have no issue with CFD at all. It's a wonderful tool when used correctly. My original question had to do with why was Paulo so certain CFD had been used to design those tandem keels?
Bob's Blog ....
bobperry is offline
Tags
boat buying , newbee advice
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 03:52 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 12:51 PM
4 ft draft, full keel, 30' and over? birdlives Boat Review and Purchase Forum 6 09-18-2010 12:00 AM
Older Full Keel boats JerryO39 General Discussion (sailing related) 30 06-09-2010 10:06 AM
Bristol 32'' full keel johnblsc Boat Review and Purchase Forum 2 12-13-2002 06:37 AM
