Full or fin keel? - Page 85 - SailNet Community
 247Likes
post #841 of 847 Old 05-22-2013
Re: Full or fin keel?
OK. Thanks for the clarification.
Vindö 50
copacabana is online now
post #842 of 847 Old 07-09-2013
Still going,eh?
Seems to me that one of the design problems with modern beamy hulls equipped with high aspect ratio and deep fins, and the resulting high bending stresses at the foil to hullbottom join, could be alleviated by using two foils, in a "V" configuration, with the bottom ends joined at the ballast bulb below and the top end affixed to the hull near the chines or bilges. The foils then are in almost pure tension and compression, aside from the lift force, with almost no bending stress.
Has anyone tried this?
K E Froeschner
Martin, Froeschner & Associates
Morgan 45 "Orion"
keforion is offline
post #843 of 847 Old 07-09-2013
grumpy old man
Kefer:
Not a bad idea. In a heeled position one leg of the fin woud be near vertical and that's good. The problem with any configuration of "tandem" keel isthat you have two trailing edges and more drag. There are a number of way to join high aspect ratio fins to hulls. On the SLIVER project we spread the loads out with a series of steel floors that all fasten to the outboard longitudinals that form the front of the setee faces. Keel bolts are well outboard in a T flange and extend all the way up through the floors. I'll see if I can find a photo.
The problem we had with the SLIVER was that the strip planked cedar hull was not capable of taking the keel bolt compressive loads without crushing. So we have to take the loads off the skin entirely. The wood strip planking was removed in a big pan shape around the keel and replaced with solid laminate.
Ok, found one:
Bob's Blog ....
bobperry is offline
The Following User Says Thank You to bobperry For This Useful Post:
keforion (07-29-2013)
post #844 of 847 Old 07-29-2013
Bob:
Thanks for the reply and photo of Sliver's floors. Looked up "the Sliver Project" on the web ... OUTSTANDING.
Nice to read of your love of Wm. Garden. I checked his books out of the libary as a kid and pored over them for so long that they eventually fell apart -- maybe it was just books with his designs in them. And your love of 30 Square's as well. There was one moored in Mariner Lagoon for years that I drooled at. It was eventually hauled to Svendsen's in Alameda and rebuilt by Peter Schwab. He raced in the Singlehanded Transpac to Japan, but I can not recall the result. (Probably won.)
Sorry for the thread drift -- but, just had to thank you.
"Bob, You done good."
kef
keforion is offline
post #845 of 847 Old 07-29-2013
grumpy old man
Kef:
I still have the Garden design catalog he gave me whan I was 15 years old and depsite being referred to and read countless times I am happy to say it is not falling apart. I know where it is right now. I always know where it is. Wish I had had the brains to have had him sign it.
The SLIVER Project boat was moved last week to the yard in Seattle where it will be finished. Here are some pics
Bob's Blog ....
bobperry is offline
post #846 of 847 Old 07-29-2013
Moderator
Jeff_H's Avatar
One of the things which is happening on the more extreme versions of the small root keels is that they are building 'cassette' style keel connections in which the end of the keel inserts into a tightly fitting box inside the hull. This allows a much bigger contact area to resist bending and torsion. Of course the box needs to be heavily constructed and needs a sophisticated transverse and longitudinal framing system to be able to distribute loads outward into the hull.
FWIW I like Garden's work aesthetically and from a historic point of view.
Jeff_H is online now
post #847 of 847 Old 07-29-2013
mstern's Avatar
That sounds like what Seaward does with its retractable keels; the high aspect keel slides up and down a box that looks (at least on their website's videos) to be rather robustly incorporated into the hull. Makes sense as a way to spread the load of a grounding even if the foil is nonmoving.
mstern is online now
Tags
boat buying , newbee advice
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 02:52 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 11:51 AM
4 ft draft, full keel, 30' and over? birdlives Boat Review and Purchase Forum 6 09-17-2010 11:00 PM
Older Full Keel boats JerryO39 General Discussion (sailing related) 30 06-09-2010 09:06 AM
Bristol 32'' full keel johnblsc Boat Review and Purchase Forum 2 12-13-2002 05:37 AM
