Engine Fogging - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 12-15-2003
paulcyre is on a distinguished road
Engine Fogging
Is there any reason why other motorized products such as snowmobiles, lawnmowers etc cannot be fogged for storage when they will not be used for a period of time?
Paul V21
Old 12-15-2003
paulk's Avatar
paulk is on a distinguished road
Engine Fogging
What is engine fogging? Have never heard of it.
Old 12-19-2003
DelmarRey's Avatar
DelmarRey is on a distinguished road
Engine Fogging
There are two types of fogging.
The first is for underway, mostly for outboards or inboards with high exposure to the elements. It is the use of a product called Salt Away mixed in a spray bottle in solution. It is sprayed on the engine and machinery and allowed to dry. This helps to eliminate the build up of salt crystals on componates.
The second is for winterizing. It is WD-40 sprayed onto the engine and machinery to protect it from moisture buildup during the wet season. In the spring it can be wipped down with a cotton rag.
Also in addition to WD-40, a heat lamp on an enclosed engine compartment keeps down the moisture build up.
Old 12-20-2003
JeffC_ is on a distinguished road
Engine Fogging
components
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
slight oil slick in diesel engine exhaust mcagney Gear & Maintenance 5 04-15-2010 12:54 PM
engine facing aft with saildrive installation levenezia Gear & Maintenance 3 01-16-2005 11:35 AM
Engine Removal drynoc Gear & Maintenance 4 01-04-2005 07:21 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
