Dinghys, where? - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Old 03-02-2001
mrey is on a distinguished road
Dinghys, where?
Interested in current thoughts on storing hard dinghys when cruising (coastal and offshore). On the deck still seems to be preferes? Davits (with cover for dinghy)?Towed?
Thanks
Old 03-02-2001
walt123 is on a distinguished road
Dinghys, where?
On the foredeck is I think the most common since it has the most uncluttered room..It is where I stored mine for almost 15 years of cruising. Some store it under the boom on passages..if they have a skylight it can be cracked open and hopefully no errant water splashes will enter the cabin. Davits have a number of drawbacks for cruising boats since most have vanes and in the med moor stern too. The only problem state side I see is most marinas charge for the overall length of the boat so the dingy on davits would be included. The size and clutter or the deck will determine where you will store yours.
Old 03-05-2001
hamiam is on a distinguished road
Dinghys, where?
The biggest problem with davits is that they do not suspend the dingy high enough in rough seas and when the boat is heeling. IE: the dingy can fill with water and become a complete nightmare. The foredeck, in my opinion, is also a less than optimal place for a dingy as it may prevent access to the foresail and/or anchor area at a time when access is most needed. Personally, if you have the room and it does not interfere with the boom vang or running rigging, I like the area under the boom on top of the cabin house. Towing it behind is another option if you can 1. get the painter length correct for the seas and 2. don''t mind the drag. Obviously, take the motor off first.
Old 03-05-2001
Dinghys, where?
Thanks for the good ideas.
Hard Dinghys out there? dsprygada Gear & Maintenance 13 08-29-2004 12:14 PM
Dinghys - inflatable vs rigid capedory30 Gear & Maintenance 5 01-06-2001 08:42 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
