Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
  #11
Old 05-18-2012
priscilla's Avatar
priscilla is on a distinguished road
Re: Topping Lift Vibration
Aac is right, take the tension off the topping lift...its that simple!
Priscilla
  #12
Old 05-18-2012
FSMike's Avatar
FSMike is on a distinguished road
cktalons -
Used to have the same problem on an infrequent basis. Sometimes we could cure it by increasing the tension, otherwise we gave up and ran the main halyard to the end of the boom and used it for a topping lift. That made me think that a larger diameter topping lift would fix the problem, but we never got around to it before the boat was sold.
Sail Fast Live Slow
40' Norman Cross trimaran
  #13
Old 05-18-2012
MarkSF is on a distinguished road
I have a bungee cord that secures the boom when at rest, goes around the backstay. A second one out to the shrouds stops the main halyard from banging against the mast.
Bristol 31.1
  #14
Old 05-18-2012
chris_gee is on a distinguished road
The topping lift vibrating and making a noise is fairly common when the wind speed is such to set up a harmonic with the length and tension. You can vary the length slightly by raising or lowering the boom and can vary the tension by tightening or loosening the mainsheet, to break the harmonic.
Tags
humming mast , mast hum , topping lift
You may post attachments
You may edit your posts
Topping Lift sehopkins Learning to Sail 11 3 Weeks Ago 01:21 PM
topping lift ralphmacey Gear & Maintenance 19 12-24-2008 06:29 AM
topping lift wumhenry Learning to Sail 24 08-04-2007 02:19 PM
Re-rig topping lift bestfriend Gear & Maintenance 26 07-30-2007 12:02 PM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
SEO by vBSEO 3.6.1
