Good sleeping bag for sailing - Page 5 - SailNet Community
 11Likes
post #41 of 43 Old 06-26-2012
Re: Good sleeping bag for sailing
Originally Posted by MarkSF View Post
I've done a bit of backpacking and my favourite combination is a thin Thermarest pad on the ground to insulate from the cold, then the inflatable Big Agnes on top. Together they're about 3.5 inches thick, nice and warm, and weigh about 3 lbs together.
Agree, I have used that combination and it works well. In hot weather I will use that in combination with a standard bed sheet, comfortable and cool.
tomfl is offline
post #42 of 43 Old 07-07-2012
windnrock's Avatar
A good liner can add about 10 deg. to the bag rating as can a cover or bivy sac on the outside. Depending on what you have to sleep on, many of the previous suggestions are great. An inflatable mattress, an inexpensive man made fiber bag good to maybe 32 deg with a couple of liners (one light, one heavy) with a breathable cover should cover most situations. You can use the covers alone for warmer and add components for cooler and colder temps. It also makes cleaning much easier! If you are on a boat an additional fleece blanket will give you even more range. Just stick with man made materials.
windnrock is offline
post #43 of 43 Old 06-13-2014
I recommend the Gauss Marine Sleeping Bag. It's layered with fleece inner and the synthetic fillings work if they get wet - unlike down-filled bags!
The Gauss bag is sold in the UK as Gauss is a British company, but they can be persuaded to ship the the US and Australia. Prices are about 189.95 ($320).
The bags are very warm when both layers are used and I know many that have never used the inner fleece layer. Personally, for sailing in cold climates, the Gauss is a very welcome, warm and comfortable treat!
Rhapsody-NS27 likes this.
markburkes is offline
Tags
sleep , sleeping
Sleeping arrangements for little ones? semirg Cruising and Sailing with Children 5 10-07-2011 06:24 AM
Sleeping at sea nasomi Learning to Sail 90 09-19-2010 12:22 AM
More comfortable sleeping? jmcgee Gear & Maintenance 14 09-28-2008 07:37 AM
Sleeping in comfort? wildcard General Discussion (sailing related) 17 06-14-2007 11:36 AM
Sleeping at the wheel Giulietta General Discussion (sailing related) 12 12-02-2006 10:35 AM
