Solar power ~ no more running the engine - Page 16 - SailNet Community
 35Likes
post #151 of 164 Old 07-25-2012
Re: Solar power ~ no more running the engine
Originally Posted by foggysail View Post
Yes, I share your concern but my concern is with the panel not the battery unless the battery is left completely unattended. I might install the panels along with the wiring next week without using them to charge anything. I don't want to damage them before I even get to properly use them. Thanks for sharing your concerns--
Foggy
Your panels can be directly connected to batteries in parallel safely. However you will need to monitor the battery voltage carefully and switch off one or both panels when the voltage climbs too high.
The Voc of 21v is not a factor. When connected to the batteries the voltage will be the battery voltage dependent on the input current. It will be an appropriate charging voltage untill the SOC of the batty climbs. When this happens you need to turn off a panel or turn on a load to keep the battery voltage appropriate. If you do not do this the battery voltage will rise to a dangerous level.
I have regulated systems like this on boats successfully for many years before controllers were effecient and affordable.
If you are going MPPT in partucular get a good one.
Outback are the best, but for a resonable cost look at the Rogue.
noelex77 is offline
post #152 of 164 Old 07-25-2012
Maine Sail's Avatar
OK, a good suggestion! I do have a concern although it is more so related to specs-. The Prostar 15 might be border line with panels rated at 8 amperes or so maximum. But then again most of the time the current will be less.
I am giving this controller serious consideration, I might order one in the morning. If so I will get the one without the meter. I just purchased a couple of hall current sensors that I need to build up. It needs a simple op amp plus a digital meter which I have several in my office. I prefer using I2C meters but for this application, a simple directed reading LCD volt meter should work fine with hall sensor.
MORE LATER--
Foggy
They also make a ProStar 30....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #153 of 164 Old 07-25-2012
I just ordered Prostar 15. More later--
Foggy
AncientTech likes this.
foggysail is offline
post #154 of 164 Old 07-25-2012
Foggy
If its 12v I am not sure that's big enough most 140w panels will produce close to 8A.
Edit:
I see you considered that, but ordered it anyway.
Most regulators will cope with a higher current and just limit to their maximimum rating. I never like to rely on this, but it won't cost you a lot of power. Check with the specifications to make sure, some just emit smoke when you go over their rating.
noelex77 is offline
post #155 of 164 Old 07-25-2012
Noelex---
Sometimes you guys remind me of WIFEY!!!! WHAT DID YOU DO THAT FOR?????????
Yes, I did think about the 30 ampere unit, ruled it out because the cost was doubled at least where I looked previously.
I purchased the 15 ampere unit this morning from SolarHome.org. After reading your post and weighing how I made the trade off whereby I selected the 15 ampere unit, I rechecked the price of the 30 ampere unit at SolarHome where I placed my order this morning. Cost differences was $34.50! I quickly called the company who was wrapping my order for shipment and asked to upgrade to the 30.
Guess it was a wise move for the cost difference. What motivated me earlier to go with a 15 ampere controller was my thought that we most likely will rarely see enough sun to get the full 8 amperes output, If we did, weeell, so a couple of mosfets/diodes would just have to run hotter. But after reading your post I again thought, suppose I add another panel next year, then what?
Thanks Noel for posting a concern and yes, the voltage is 12 not 24.
Foggy
mdi likes this.
post #156 of 164 Old 07-25-2012
Noelex---
Well I am glad we are not sharing accommodation, otherwise I would be nervous
I think you made the right decision.
noelex77 is offline
post #157 of 164 Old 07-25-2012 Thread Starter
is Awesome!
Send a message via Skype™ to DavidB.UK
Hi everybody,
Thought this might be of interest and oddly relevant to this thread...
DavidB.UK is offline
post #158 of 164 Old 08-03-2012
Hi, I put in a system on my houseboat with 4 solar panels/6 batteries and the cost ran about $5000 US, it generates about 2.2 KW per day on a good day, which is enough to run the refrigerator and a few other things and the boat lights and equipment.
But the reality is, it can not do that consistently, I can go 3 days or so out on the hook with no generator but after that it becomes a game of how much sun do I get.
It would be possible if I had more solar panels and batteries to do more but at the moment till the costs on solar panels comes down a lot more it is not cost effective IMO.
Hope that helps happy to share more details if your interested.
CRHODES is offline
post #159 of 164 Old 08-10-2012
Getting close! Tomorrow I should have my system up! I mentioned earlier that I purchased the Prostar 30 without the pricey meter. I just finished building a meter assembly that I stuffed into a plastic weather proof electrical box. I cut the blank cover to mount the meter which was calibrated to a 75mv shunt for 50 amperes. (edited--thanks to Hellosailor) I mounted the shunt on the rear of the box.
Finally I installed a jack that accommodates a 5.6 volt dc output from a transformer that will power the meter with about 5 vdc rather than the 12vdc that the meter is rated for. I found that the meter gets hot indicating the thing must have a zener diode in it for regulating. The dc output from the meter is......well it is really full wave rectified voltage with no filtering. Who cares if it works.
If anybody considers building their own metering unit, be careful to use a separate power supply...completely isolated from the supply whose current is being metered. Alsom the measuring is done on the return leg of the solar output. Enough of the simple basics.
Because the shunt can dissipate upwards to 2 watts, I have it mounted such that air can pass through the shunt for cooling. The box/shunt combo will mount tomorrow on plastic stand offs so the box will be about 3/4" off the wall giving clearance for the shunt proper.
Getting excited! We are taking next week off so it will be a good time for testing. My luck or lack of will probably see nothing but clouds and rain. More on that later. Another awe shucks! If I add another pair of panels, I will most likely exceed the rating for the Prostar. Time will tell. I have not seen any more of these panels on Amazon lately.
CRRHODES--- You must have installed your panels sometime ago, I see that your setup cost about $5K. That is way beyond what I can afford at present. If these cheapo panels were not available, I would have no solar.
Your experience provides valuable insight on what to expect. Certainly I expect to run my genny when on anchor, I just don't want to run it to charge batteries unless I have to. I want my genny to provide energy for hot water, stove.... all the basics. OH, it will have to recharge my 24vdc battery bank, I can live with that.
More over the weekend!!!
Foggy
post #160 of 164 Old 08-10-2012
"I wanted only 30 amperes to be displayed so I installed a divider across the shunt's output terminals"
foggy, I'm not quite waht you've done but can tell you this is NOT THE WAY TO DO IT.
The way meters and shunts are set up, it doesn't matter what range you want to read. All that matters is that the mv-per-display has been matched between them, and that you don't exceed the maximum amperage that the shunt can carry. Whether you want to read 10 amps, 25 amps, or 50 amps...if you have a meter and 50a shunt, they are set up the same way regardless.
I would strongly suggest that what you've done now is simply to distort all the readings. And, perhaps, that's related to the shunt overheating as well.
Some of the bargain stuff from China, which is SO attractively priced, almost scares me. The shunts are visibly different from the pricey domestic ones, and the all-in-one digital meter displays seem to vary quite widely in quality. (I've got two that never agree, even though they are supposedly calibrated and way exceed their display accuracy.)
50A shunt, 50A meter, put it back to the original configuration and it will read 30A scales just fine. Really.
hellosailor is offline
solar power cooljetts Electrical Systems 4 04-17-2012 03:44 AM
Solar power for my MacBook radioguy Electronics 25 09-13-2010 07:10 PM
Running engines for electric power GregX999 Cruising & Liveaboard Forum 6 12-20-2009 07:34 AM
Solar Power for Liveaboards I33 Gear & Maintenance 7 01-14-2009 08:27 AM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
