butane stoves - SailNet Community
post #1 of 11 Old 07-17-2012 Thread Starter
butane stoves
I have an old butane camp stove on my boat, probably from 1987. Do the new ones heat / boil water faster? It took about 25 minutes to make a pot of coffee.
tmshaw is offline
post #2 of 11 Old 07-17-2012
Re: butane stoves
Camp stoves vary enormously. I have a one burner backpacking stove that's about 15,000 btu. Then my two-burner Coleman folding stove is half that, 7000 per burner I think.
REI usually has a bunch you can try in the store. The variation is huge.
MarkSF is offline
post #3 of 11 Old 07-27-2012
Old enough to know better
Re: butane stoves
Yes, I have a Butane burner that is like what they use in restaurants for table service and omelet stations, but is a cheap copy, and it heats very quickly. The canisters of butane are kind of expensive though.
miatapaul is offline
post #4 of 11 Old 08-01-2012
Re: butane stoves
I had a butane (top of the line) stove in my backpacking days....POC....I went back to the old school multifuel ones.You could just about melt lead with them.
ParadiseParrot is offline
post #5 of 11 Old 08-01-2012
Sundance 23
carl762's Avatar
Re: butane stoves
I have one of the table top butane stoves, used it in backyard, and works fine. Haven't used up a canister yet. I get them at a camping store for $1.69 a pop. You can get them cheaper on Amazon. I plan on using it as a backup stove only.
Water is Life
carl762 is offline
post #6 of 11 Old 08-08-2012
Re: butane stoves
Hi,
Most modern stoves can do a liter in abt 3 mins so that might tell you something.
Of course a lot of those are using iso/butane mixes now in the canisters - the multi-fuel jobbies that other guys talked about are true - you can get models that will flash water to a vapor in mins but they don't simmer that great and butane might be safer onboard.
They're way safer to light - becasue of no priming but you get less bang for the buck with butane vs. white gas or napatha stoves - fuel costs (another word for multi-fuel)
If yer scooting around the world multi fuel are great becasue they burn everything.
Cheers'
Dave
davecason is offline
post #7 of 11 Old 08-09-2012
Sundance 23
carl762's Avatar
Re: butane stoves
Also, I really like mine, because it's packaged in a hard shell case that stores nicely in the bilge.
Water is Life
carl762 is offline
post #8 of 11 Old 08-09-2012
Working for next Boat
MobiusALilBitTwisted's Avatar
Re: butane stoves
Handle Butane the same as Propane, it is heavier then Air, and needs to be stored out side.....
S/V
1985 Venture 25
Fl Gulf Coast
GrahamO
"Möbius,You need another drink. You are starting to make sense".
MobiusALilBitTwisted is offline
post #9 of 11 Old 08-09-2012
Sundance 23
carl762's Avatar
Re: butane stoves
Good point, didn't know that about Butane. I'll put my fuel in the dockbox, way away from the boat.
Water is Life
carl762 is offline
post #10 of 11 Old 08-13-2012
Re: butane stoves
Use a jet boil........makes water boil
in around a minute.........
/I do not sell them nor in anyway am I affiliated with them......They just heat the water very very fast.
AKscooter is offline
Butane stove dvuyxx Gear & Maintenance 10 05-01-2012 06:19 AM
Propane, butane, CNG Yofy Cruising & Liveaboard Forum 13 11-11-2007 12:42 PM
Butane to Propane conversion Ovniman Gear & Maintenance 5 07-31-2005 05:50 AM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 08:00 PM
From Propane to Butane John Kretschmer Cruising Articles 0 09-23-1999 08:00 PM
