Solar coffee maker? - SailNet Community
 4Likes
  • 1 Post By Minnewaska
  • 1 Post By BluemanSailor
  • 1 Post By ParadiseParrot
  • 1 Post By miatapaul
post #1 of 10 Old 08-08-2012 Thread Starter
Senior Moment Member
AncientTech's Avatar
Solar coffee maker?
Ha! Good idea for those out at anchor. I have 2 of those short solar vacuum tubes in the garage! Wondering how the water temp/flow will effect the coffee flavor. I am so going to try this with my old busted coffee maker!
"I am of the mind that anything with a proper sail attached to it has the potential to profoundly alter ones concept of the world."
Morgan 22
Naples, FL
AncientTech is offline
post #2 of 10 Old 08-08-2012
Boatswain
IronSpinnaker's Avatar
Re: Solar coffee maker?
Interesting, but 40 minutes is a long time to wait for coffee... and that thing is kinda large for a boat.
Signature
IronSpinnaker is offline
post #3 of 10 Old 08-08-2012
I recall having Sun Tea, as a kid. Just throw a bunch of tea bags in a clear jug full of water and leave out in the sun all day. I think I would just switch to tea.
AncientTech likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 10 Old 08-08-2012
You can brew coffee with almost anything but you could also do a little digging online. Coffee is usually brewed at something like 201? 205? degrees and there are reasons for the specific temperature, involving how the compounds are extracted from the beans.
The original Mr. Coffee used to have problems because they didn't regulate temperatures correctly, while Krups and Braun did. Mr. C. has caught up in recent years.
The megabuck espressomakers in coffee bars usually allow for temperature settings within 1/2 degree, and each shop decides where to set that.
So if you check the temperature needed and set up your solar rig to match it, you'll get good coffee if you have enough water volume to brew it before it turns into an all-day affair.
hellosailor is offline
post #5 of 10 Old 08-08-2012
Old enough to know better
Yea, that thing looks like a fun project to waste some time in the back yard, but not for coffee on a boat. It is a lot of space taken up for one purpose, of course I guess you could use it for general hot water, that might make more sense. But putting a pot of water on the stove and pouring it over a filter is easy, this contraption not so much so. I wonder if you can get enough sun in the winter to use something like this for heat? That could be interesting, solar hydoronic heat. I'll bet those vacuum tubes make a big bang when they blow!
miatapaul is offline
post #6 of 10 Old 08-08-2012
BluemanSailor's Avatar
You can also make cold brewed coffee! I couldn't drink coffee for the longest time - I have GIRD and the acid in the coffee killed my stomach until I discovered cold brewed. Take a pound of coffee - mix with 8 cups cold water let it sit for the night , then drain/filter and you end up with a coffee syrup. Mix it with boiling water - you can make it as strong as you like - taste great even a little on the sweet side, so my die hard starbucks drinkers say!
With a pound of coffee I ended up with about 35-40oz of syrup. also I use this system..
Toddy Coffee Maker at Toddy Cafe: Cold Brew Coffee, Acid Coffee Low, Coffee Brewer, Best Coffee Maker
slax likes this.
Roland
Sailor - kayaker - woodturner - Photographer.
New boat sailblog -
BluemanSailor is offline
post #7 of 10 Old 08-08-2012
Yea my local coffee house (and now beer house!) has one of the fancy cold drip things that has swirls of glass tubes. I have not tried it yet though. I normally have them make a pour over for me.
post #8 of 10 Old 08-08-2012 Thread Starter
Wow, the cold brew options actually look interesting. Even some of the luke warm drip systems do too. I had no idea there were so many decent options available beyond the old school methods. Will have to give them a try soon.
Morgan 22
Naples, FL
post #9 of 10 Old 08-09-2012
Why are his hands shaking? Maybe he should make a Solar meth pipe.
AKscooter likes this.
ParadiseParrot is offline
post #10 of 10 Old 08-09-2012
Hey if it took over 40 min to make coffee in the morning you would be shaking too!
Coffee Maker nauticalrich General Discussion (sailing related) 85 05-04-2012 09:43 AM
water maker solar panels warrenbear Introduce Yourself 4 04-27-2012 02:40 PM
Coffee mcain Provisioning 109 06-29-2010 02:12 PM
What do you use for a coffee pot? Garffin Gear & Maintenance 59 12-14-2009 11:01 AM
Best Coffee Maker scurvy General Discussion (sailing related) 33 09-04-2007 05:30 AM
