- Quick Menu
3Likes
09-30-2012
Re: Galley counter top material
Also try some local kitchen/bathroom cabinet shops. Bib box stores don't build any of that stuff, just sub it out for build and install. In bigger towns to local cabinet manufacurer. Whenever possible, go to the source.
09-30-2012
Originally Posted by SlowButSteady
Ummm....
A slab of stone, 100-200 lbs (or more?) of added weight, several feet above the boat's ballast and maybe off-center.
Does anyone else see a problem here?
I'd snicker audibly if there were any of these on board:
* Cored panels
* Carbon fiber anything
* High modulus lines
* High modulus sail fabric
* Mattresses lacking inner springs
But perhaps my priorities are misplaced.
I've had both laminate and gelcoat. My PDQ has gelcoat over a cored panel, which seems smart. Both did fine in the long run. Heck, they last through decades of daily home use, generally going out of style before wearing out.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
10-01-2012
Yep. Formica does seem to be one of the best, if not the best, brands of laminate. However, as far as I can tell, the difference in quality among the best brands is pretty minimal.
Ooooh, I disagree with that second statement. We had some kitchen work done and failed to specify "Formica" brand and the crap we got was a real PITA. Stained if you look cross eyed at it and scratched very easily. Even doing cross word puzzles in the newspaper left stains.
One of the best kept secrets is butcher block. Doesn't weigh much more than 1.5 inches of ply plus formica, is easily sealed with tung oil, which can be renewed and is easily restored with light sanding and re-oiling.
10-01-2012
Originally Posted by msmith10
Formica is just a brand name for laminate.
Yep. Formica does seem to be one of the best, if not the best, brands of laminate. However, as far as I can tell, the difference in quality among the best brands is pretty minimal. Go to you local Home-Depot/Lowes/whatever and take a look. They usually a basic selection in stock, and you can always order whatever color you want. I would stick to a solid color, rather than a pattern, as patterns almost always look tot busy in a small space (like a boat galley).
thank you both.. appreciate your help!
10-02-2012
I bought enough type 316 stainless to cover my galley counters for $13 , from a scrapyard. If you find restaurant stainless in a scrapyard, sometimes you can find it with a galley sink molded right in . You can put anything hot directly on it, with no worries. Best counter top available . Restaurants have figured that out long ago.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
10-05-2012
Any pics? It sounds awfully industrial, but I work in a machine shop so there is more stainless laying about then you can shake a stick at, so it would be dang easy to just slap on top of the existing laminate(yellow yuck).
10-05-2012
Originally Posted by CapnBones
Any pics? It sounds awfully industrial.....
It sure is. The kitchen in a restaurant is designed to be efficient and clean, not homey. Dents and scratches are part of the territory.
While not advised, you can put laminate on top of laminate, particularly if the edges are covered with a fiddle.
Jeanneau 54DS
10-05-2012
formica gets dings and gouges easily--was used extensively in the 50s-70s in tract housing. is a pita, as it isnt durable and not beautiful for quality work. is a poor tribute to the builders who used the cheapo materials to save dough and offer boats at mid income pricing.
i will mebbe go to corian or granite, as that extra weight is not a problem with my heavy displacement cruiser. maybe be impractical on a racing boat, but this aint that....
formosa 41 and ericson 35mII
cruising mexico at present, working my way southward
10-05-2012
I have some pink Corina from remodeling the kitchen. If you want a hunk, pm me and
we will work something out. I think the problem with any of the thick counter top materials, Corian, granite, soapstone, ect is the additional work around the sink, faucet, icebox and stove as well as the fids. The stainless steel approach is practical as well as functional but a bit cold aesthetically IMHO.
10-05-2012
I would not say that laminate scratches or dings easily, but certainly more easily than stone or corian. Best to use light colors that won't show minor abrasion. The real problem is, if you do scratch it, you have to live with it.
They do make some laminate patterns that don't look as 60s as they used to.
Jeanneau 54DS
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
