Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Like Tree3Likes
  #41
Old 10-08-2012
copacabana is on a distinguished road
Re: Galley counter top material
Originally Posted by poopdeckpappy View Post
Another alternative is soapstone (saratoga soapstone) kinda in between a corian and granite, very elegant looking
But very soft I would imagine.
One of the advantages of granite is that it is very hard, making it pretty much scratch proof and long lasting. I'm thinking of going with granite when I re-do my galley. It's very cheap in Brazil (starting at USD100 per 10 sq. feet, installed).
Vindö 50
  #42
Old 10-08-2012
MysticGringo's Avatar
C&C 34
MysticGringo is on a distinguished road
Send a message via ICQ to MysticGringo Send a message via AIM to MysticGringo Send a message via Yahoo to MysticGringo Send a message via Skype™ to MysticGringo
Has anybody tried a liquid glass like product? It's the clear epoxy you see on bar and table tops at restaurants. You can embed all sorts of things prior to pouring.
Cutting boards become necessary.
-MysticGringo
  #43
Old 10-08-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Soapstone varies quite a bit in composition, but it can be very soft: as low as about 2 on the Moh scale (fingernails, 2.5 Mohs, can scratch it). However, the soapstone used for countertops is usually a bit harder, at around 4 to 5 Mohs (slightly harder than Corian, which is usually about 3.5 Mohs). Still pretty easily scratched, particularly in a place as busy as a sailboat cabin.
LET'S GET SERIOUS ABOUT GUN CONTROL, NOW!
  #44
Old 10-08-2012
Minnewaska will become famous soon enough
Originally Posted by copacabana View Post
...One of the advantages of granite is that it is very hard, making it pretty much scratch proof and long lasting. I'm thinking of going with granite when I re-do my galley. It's very cheap in Brazil (starting at USD100 per 10 sq. feet, installed).
Nothing is perfect. Granite is also porous and must be sealed (and maintained) or it can be permanently stained.
Jeanneau 54DS
  #45
Old 10-08-2012
Originally Posted by MysticGringo View Post
Has anybody tried a liquid glass like product? It's the clear epoxy you see on bar and table tops at restaurants.....
I applied this to a bar top in my rec room at a previous house. It is easily scratched. Coasters, placemats, etc were needed religiously. If you look at one in a bar, they are hazed over by the scratching, although, don't look too bad. I'm also certain they can't take much heat.
Installation is probably the tougher part, unless you can remove your counter tops from the boat. They need to be perfectly level, and I mean perfectly. The stuff seeks a level and the slightest imperfection will be noticed over the length of a counter. No way any of our boats are that level. The advantage, however, is that the fids will provide a natural barrier to hold the stuff in place. Letting it run over the edge is very difficult to get right.
Jeanneau 54DS
  #46
Old 10-08-2012
Minnewaska, I've never had a granite counter at home stain, but I suppose it's possible. Marble is porous and stains easily. Granite (at least the Brazilian stuff) stands up to a lot of punishment and keeps looking great. The weight is a bit of an issue on a boat though ...
Vindö 50
  #47
Old 10-08-2012
ccriders is on a distinguished road
Corian, marble and granite cannot take a hot pan right out of the oven or off the burner. If you need this capability look at the synthetic granites; stilestone or caesar stone. The color and detail variations are enormous and can be templated to fit the unusual shapes and dimensions of a sailboat. It is incredibly strong and very easy to clean up. It is price competitive with granite and more so if you go looking for decorator granite. The only draw back is its weight, which is only important on a smaller boat like mine.
  #48
Old 10-08-2012
C&C 34
Cool. I wonder if there are different versions with different levels of hardness. A few I've seen still remain pretty clear. One I saw said it'd withstand 270 degrees without marring or staining... so not hot pan or pot, but definitely coffee or plate worthy.
My galley is pretty tiny, so I'm not worried about seeing it out of level for a portion... but the chances of getting the boat to stop swaying back and forth during installation is pretty slim. I may try it and do a write up.
-MysticGringo
  #49
Old 10-08-2012
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Granite can't take the heat? Huh?!?
One of the reasons for granite as a countertop material is that it CAN take the heat of a 400º pan without a problem...
HowStuffWorks "How Granite Countertops Work"
... Formed ov*er millions of years from compressed molten rock under the Earth's surface, granite is extremely hard and durable.
With its heat-resistant qualities, granite doesn't blister; it's also unlikely to scratch or chip. When used for kitchen countertops, it's far superior to marble, synthetic and laminate...
Granite is porous, and it will stain if you place oil on it.
  #50
Old 10-08-2012
Captainmeme's Avatar
Captainmeme is on a distinguished road
Wasn't there a thread where some of the members of this forum gave grief to a guy who lost his boat that was equipped with granite counter tops? Something about spending money on counter tops and not on essential gear.
I'm finishing the interior of me boat. While we have granite in the kitchen and and an old corian top in the garage I'm going with high pressure plastic laminates, Formica.
You may post attachments
You may edit your posts
Galley counter-ceramic tiles QuickMick SailNet FAQ's 10 10-07-2012 06:15 AM
vinyl mats and galley counter QuickMick Gear & Maintenance 17 01-13-2011 05:37 PM
Replacing galley counter L124C Gear & Maintenance 7 02-25-2009 02:15 PM
Yanmar rev counter Omatako Gear & Maintenance 6 06-26-2008 03:29 AM
Repair of galley counter ricka Catalina 2 12-02-2006 10:32 PM
SEO by vBSEO 3.6.1
