Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum
Like Tree3Likes
  #51
Old 10-08-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Galley counter top material
Originally Posted by MysticGringo View Post
My galley is pretty tiny, so I'm not worried about seeing it out of level for a portion... but the chances of getting the boat to stop swaying back and forth during installation is pretty slim. I may try it and do a write up.
Why not do it when you haul for bottom paint? Just spend the time to carefully level the boat when you block it.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #52
Old 10-08-2012
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Originally Posted by Captainmeme View Post
Wasn't there a thread where some of the members of this forum gave grief to a guy who lost his boat that was equipped with granite counter tops? Something about spending money on counter tops and not on essential gear.
Yes, Doug Sabbag of S/V Triumph. There is a thread about it in here.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #53
Old 10-08-2012
ccriders is on a distinguished road
Originally Posted by eherlihy View Post
Granite can't take the heat? Huh?!?
One of the reasons for granite as a countertop material is that it CAN take the heat of a 400º pan without a problem...
HowStuffWorks "How Granite Countertops Work"
Granite is porous, and it will stain if you place oil on it.
Yeah, I know all that stuff about granite. I've also seen it cracked when a heavy roasting pan was put on it straight out of the oven. I've also seen it with a big chunk broken off the edge where someone hoisted themselves up on the cabinet top. Plus, it has to be maintained, not just cleaned.
Remember, granite is full of imperfections that can be the source for cracks and chips. Plus it is ugly unless you purchase really expensive stuff.
  #54
Old 10-08-2012
SloopJonB's Avatar
If you want real stone counters on a boat, granite tiles are a pretty good option. They weigh a lot less than full stone tops and if you're careful with your grout selection they are nearly indistinguishable from one piece tops, at least if you use black or dark granite with no heavy patterning.
  #55
Old 10-08-2012
MysticGringo's Avatar
C&C 34
MysticGringo is on a distinguished road
Send a message via ICQ to MysticGringo Send a message via AIM to MysticGringo Send a message via Yahoo to MysticGringo Send a message via Skype™ to MysticGringo
Because I just put the boat back in the water 2 weeks ago from painting the bottom and didn't have the time, energy or money to do the counter tops at same time.
-MysticGringo
  #56
Old 10-08-2012
Minnewaska will become famous soon enough
Granite and marble can both crack from vibration. Most builders will require you to sign a waiver if you install a garbage disposal. This can probably be limited, if you select a stone with no vein. I have jarred about every boat I've ever sailed to the point that I could loosen teeth. Stone would make me nervous.
If you've not felt like granite was stainable, I highly suspect it was already sealed.
Jeanneau 54DS
  #57
Old 10-11-2012
Sailing Chance
SailingChance is on a distinguished road
Stainless steel. May sound intimidating and expensive, but it is actually quite cheap and easy. Build a top with 1/2" plywood complete with cut outs for sink, etc. Find a local metal/steel yard (again, you;d be surprised how easy) and get 16guage stainless steel sheet. Often they will cut the pieces into your outer dimensions for you for $1 a cut. getting stainless from a metal yard is really cheap. For example, I just got 12gauge (pretty thick) 1" stainless tubing - 20' for $31.00. Compare that to anywhere else in the marine industry at $8/ft. You could probably get the whole counter for less than $100. Once you have the exterior dimensions cut and matched, you simply need to trace the openings on the underside, mark with a sharpie and cut with an angle grinder or even a dremel. There are even steel cutting blades for jig saws. Heck, the guys at the metal yard might do the whole thing for an extra $50.
  #58
Old 10-11-2012
While a SS countertop isn't my thing, I wonder about grades of SS. Lower grades can and do corrode before your eyes in a marine environment.
Jeanneau 54DS
  #59
Old 10-11-2012
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Shop with a magnet. If it's not magnetic, odds are it's 316.
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #60
Old 10-11-2012
MedSailor
I think lower grade SS can become magnetic, based on how its molded, but I don't think you can rely on a magnet to assure you it is 316.
I know you said, "odds are", but can't really say you would know what odds you were working with.
Jeanneau 54DS
You may post attachments
You may edit your posts
Galley counter-ceramic tiles QuickMick SailNet FAQ's 10 10-07-2012 06:15 AM
vinyl mats and galley counter QuickMick Gear & Maintenance 17 01-13-2011 05:37 PM
Replacing galley counter L124C Gear & Maintenance 7 02-25-2009 02:15 PM
Yanmar rev counter Omatako Gear & Maintenance 6 06-26-2008 03:29 AM
Repair of galley counter ricka Catalina 2 12-02-2006 10:32 PM
SEO by vBSEO 3.6.1
