Winter Moisture Control - Page 2 - SailNet Community
 28Likes
post #11 of 105 Old 10-31-2012
C&C 34
MysticGringo's Avatar
Originally Posted by BubbleheadMd View Post
The good news is, after a single night of having insulation installed and running the heater at full throttle, the boat is now DRY. The window frames have stopped sweating and my clothing is all dry. I still have two long panels to cut and install on the bulkheads in the v-berth, but that's all.
I'm mightily impressed.
I had a similar experience as you. This is my first winter aboard, and we stayed on during Sandy. I did everything wrong when I comes to condensation. I buttoned up the boat tight, kept bringing in wet foul-weather gear, made pasta (was warm and tasty, so I don't see it totally wrong) and only had a firepot (extremely closely watched) for heat. Every surface was dripping.
When they brought power back on, I ran a heater, cracked a vent, and am completely dry. I didn't add any insulation though. I think its all about ventilation... atleast for me. Warm air from heater absorbs the moisture, then escapes thru the hatch I have cracked open.
Jbe likes this.
-MysticGringo
MysticGringo is offline
post #12 of 105 Old 10-31-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
Re: Winter Moisture Control
Are you using an adhesive to attach it? also, did you put it in the ports?
Brass Belle
'78 Pearson 30, #1099
TheTardis is offline
post #13 of 105 Old 10-31-2012
Tim R.'s Avatar
In Maine, we ventilate and dehumidify.
DINKS14 and TheTardis like this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #14 of 105 Old 10-31-2012
Chastened
Ajax_MD's Avatar
I put it in the ports and hatches. I did not use adhesive, I simply cut it snug and let friction hold it in. I will periodically pop it out to make sure that nothing grungy is growing behind it.
If you insist on attaching the insulation somehow, I suggest using small squares or strips of velcro, so that you can remove it when the weather is warmer.
I actually sail my boat, so I don't want any of this stuff to be permanent. It's unsightly, and in plain view. I only tolerate it because winter is coming on.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #15 of 105 Old 10-31-2012
Old enough to know better
Originally Posted by flyingriki View Post
Am getting back into boating and remember that the material used to make Hypervent is actually a common material used somewhere else - maybe construction, for a hell of a lot less money. Does anyone recall where to find it outside the marine world?
It kind of reminds me of roof ridge vent material, but I think it only comes in strips.
modernbuilderssupply.com: Air Vent Easy Up Rolled Ridge Vent - Black
I know people say they use wood slats from Ikea to hold the cushions up and allow air circulation. I would imagine the Froli springs would help as well.
Bene505 likes this.
miatapaul is offline
post #16 of 105 Old 10-31-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
I sail mine as well, however I want a more permanent and aesthetically pleasing (I am a girl after all) solution. I am installing the insulation and then placing a painted facade over it. Thought being that it will keep warm in winter and help keep cool in summer.
Brass Belle
post #17 of 105 Old 10-31-2012
Chastened
Ajax_MD's Avatar
Ah, for keeping cool in the summer, I'll put Reflectix in the windows, and stretch a white or silver tarp over a portion of the cabin top. The Reflectix is much thinner and easier to work with.
I also have a CruiseAir air-conditioning unit so...
Ajax_MD is offline
post #18 of 105 Old 11-01-2012
I just use a small west marine floor heater, I have to say winter is no biggie here at 48 north, I dont do anything special and even the few weeks a year when its in the teens with ice around the boat, frozen docks and high wind I'm never cold and I'm from So cal. I let my heater run on low 24 hours a day during the coldest part of winter so the boat never gets beneath about 40 and is easy enough to heat up. I haven't done anything special as I sail year round and want to be able to leave in a moments notice.
barefootnavigator is offline
post #19 of 105 Old 11-03-2012
Corinthian
NoDogue's Avatar
does anyone use a woodstove to heat with? how does that stack up for keeping out the winter dampness?
s/v Un Canadien Errant
26' 1976 Luger Tradewinds
Salt Spring Island, BC
NoDogue is offline
post #20 of 105 Old 11-03-2012
benjiwoodboat
benjiwoodboat's Avatar
Send a message via AIM to benjiwoodboat
I've lined my boat with bubble wrap (on the inside) and used Damp Rid. We also don't heat the interior excessively. That seems to help minimize the moisture.
Ben Eriksen
benjiwoodboat is offline
Moisture Nicklaus Boat Review and Purchase Forum 10 11-07-2012 01:11 PM
Moisture!!! DLM Gear & Maintenance 7 04-08-2007 02:28 PM
Moisture dmurcott Boat Review and Purchase Forum 3 02-03-2006 08:04 AM
Using Moisture Meters Dan Dickison Gear and Maintenance Articles 0 03-03-2002 07:00 PM
Moisture Dilemma Mark Matthews Gear and Maintenance Articles 0 05-06-2001 08:00 PM
