Winter Moisture Control - Page 8 - SailNet Community
 28Likes
post #71 of 105 Old 11-10-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
Re: Winter Moisture Control
The boat or the gallery? I just logged out and tried the link and there were 22 pics there...
Brass Belle
'78 Pearson 30, #1099
TheTardis is offline
post #72 of 105 Old 11-10-2012
Chastened
Ajax_MD's Avatar
At first it said "This gallery does not contain any images". I seem them now.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #73 of 105 Old 11-10-2012
Chastened
Ajax_MD's Avatar
Jesus girl...You've done and are doing a lot of work.
TheTardis likes this.
post #74 of 105 Old 11-10-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
hehe...I've been busy! But it is so fun learning my boat this way! Also... just ordered new hatch boards! I'm a little giddy
Brass Belle
post #75 of 105 Old 11-14-2012
Seasoned Salt
Trekka's Avatar
I've spent several winters aboard in two different boats. Had terrible condensation issues the first winter but have coped better ever since. Ventilation is not just inside out. It is also about internal ventilation, making sure compartments are not sealed off. I keep most compartments open at least slightly, such as the sliding door cupboards and bins. I am a big fan of the old style ceramic heaters such as made by Pelonis. They are hard to find and not cheap. Most electric heaters found in stores are crude technology that was used by our grandparents. But good ones can be found. I prefer to have more heaters, running at lower settings. This allows far better distribution of the heat.
In addition to watching load levels (current, amps), it is essential to pay attention to every connection. The connections are the weak point where failure usually happens. A poor connection can heat up hot enough to melt and burn without tripping a circuit breaker because until two opposite wires actually cross and short there is no over-current. Everything AC electric in the boat is basically on an extension cord, as is the boat itself. Feel the connectors often. Make that part of the routine of time aboard. If the connection is very warm, either the cord is too small for the current, or the connection is poor. I use heavy guage cable and connections that can be viewed and cleaned.
I have a keel stepped mast which in the winter is a cold delivery device. I wrapped it with refelectix and that mae a big ifference. My boat has several large ports with frames get very cold in winter and hot in summer. I cut reflectix covers for them and that helps a lot, too.
I use thin foam panels and reflectix to double layer compartments and as many flat or gently curved surfaces as I can. I have big overhead hatches in my boat that are great for light and ventilation in warm weather, but are escape paths for heat in winter. I cut inserts of the thin foam and fit them inside the hatch. Cuts heat loss markedly.
I also use a lot of Damp-Rid. It works great and can be affforable with careful buying. I get the hanging type in 3-4 pack boxes at WalMart, Home Depot, Lowes, and the like. Usually for $8 or so, sometimes less on sale. One of those in the hanging locker makes a HUGE difference. I also use the tub type as it is far cheaper. The refills can be bought in bulk, enough to fill 3-4 tubs for maybe $3. Sometimes the absorbant grains can be bought as sidewalk ice melter for even less cost. I place tubs where they won't slide and have never had one tip. They make a huge difference.
Baking warms the cabin up nicely, too.
Trekka CSY33
Trekka is offline
post #76 of 105 Old 11-14-2012
Originally Posted by Trekka View Post
......Baking warms the cabin up nicely, too.
It does and I love the smell of baking aboard.
However, both the food and propane add substantial moisture to the boat.
Jeanneau 54DS
Minnewaska is offline
post #77 of 105 Old 11-14-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
But the cookies will taste fantastic while you get "rained" on!
Brass Belle
post #78 of 105 Old 11-18-2012
thedude's Avatar
we are a family of 4 (lots of condensate) living on a 36fter off the magothy. we're currently heating with 2 small ceramic heaters that both heat and dry our boat quite well. haven't insulated yet and still contemplating the bulkhead diesel heater for times when the power goes out (thanks sandy) and when we are on the hook. i will say, we pay a flat fee for electric/liveaboard. otherwise we'd be burning diesel now.
thedude is offline
post #79 of 105 Old 11-20-2012
Seasoned Salt
Trekka's Avatar
Forgot to mention that a major area of heat loss is through the cabin sole. The cold water is a great conductor of heat out of the hull. I bought some cheap, rubber back carpet runners at KMart and cut to fit the main cabin sole. And some smaller runners for the sole leading to the forepeak. Made a big difference. This year I am about to do same but this time will first put down a layer of thin blue foam. 1/4"? That with carpet over it will do even better.
Trekka is offline
post #80 of 105 Old 11-20-2012 Thread Starter
Rogue Musician
TheTardis's Avatar
I had actually thought about that. Hadn't thought about the extra layer of foam though.. what kind of foam is it?
Brass Belle
Moisture Nicklaus Boat Review and Purchase Forum 10 11-07-2012 01:11 PM
Moisture!!! DLM Gear & Maintenance 7 04-08-2007 02:28 PM
Moisture dmurcott Boat Review and Purchase Forum 3 02-03-2006 08:04 AM
Using Moisture Meters Dan Dickison Gear and Maintenance Articles 0 03-03-2002 07:00 PM
Moisture Dilemma Mark Matthews Gear and Maintenance Articles 0 05-06-2001 08:00 PM
