Induction vs electric vs alcohol stove? - Page 4 - SailNet Community
 3Likes
post #31 of 34 Old 01-31-2013
Re: Induction vs electric vs alcohol stove?
Originally Posted by Alex W View Post
They throw up high flames when they are priming, flames that are likely to catch curtains over your stove area on fire.
White gas is highly refined gasoline, and not something that I want to carry a lot of on my boat, especially inside the cabin.
Alcohol stoves (like the Origo) are a lot simpler, effective, and safer.
Mine doesn't do all that, I have a multi-fuel version that also uses kerosene. Like I said, I like it, the only thing I don't like about it is that it doesn't have a good surface on top so only works when your boat is very steady.
What are you pretending not to know ?
Please support my
wind_magic is offline
post #32 of 34 Old 02-01-2013
davidpm's Avatar
Originally Posted by Bob142 View Post
I have been cooking with induction at home, work and on the boat on shore power for a couple of years...but when I plug in to my inverter it doesn't work...it is a 1750 inverter so I am going to try a 3000...
Let us know how it works.?
What model are you using.
It will be interesting to know how many amps it draws.
davidpm is offline
post #33 of 34 Old 02-01-2013
davidpm's Avatar
Originally Posted by guitarguy56 View Post
Regarding the solar panels... Yes... 8 feet long 18 inches wide and as flexible as a 1/8th inch plastic panels... in fact I have it rolled up as we speak in a coil that is only 12 inches diameter stored for use... they work fantastic... so when I get ready to get my dodger made they'll be incorporated on top of the dodger getting all that glorious sun in Georgia/Florida...
Which panel are you using?
What kind of real world output are you getting?
davidpm is offline
post #34 of 34 Old 02-01-2013 Thread Starter
guitarguy56's Avatar
David... the solar panels are in Savannah, GA... I'm up here in Seattle... so the panels will not be installed on the dodger till I get the sailboat down there... but regarding the power it's 144 watts at 12v and it's very efficient at charging 2 banks of 12v batteries... I have two of these panels and looking forward to getting them installed.
Regarding the inverter... make sure it is a 'pure sine wave' type inverter... mine is a 2000 watt Prosine unit... very costly unit >$500... brought it some time back in Savannah and brought it up here with the cooktop... it works perfectly.
I'll take a picture of the unit tomorrow sometime... try to post it online...
guitarguy56 is offline
alcohol stove dubon General Discussion (sailing related) 10 08-06-2012 06:44 PM
alcohol stove questions Kiltmadoc Gear & Maintenance 7 06-23-2010 07:23 AM
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Non-Pressurized Alcohol Stove SEMIJim Gear & Maintenance 32 11-09-2007 10:53 PM
Using an alcohol stove Bermuda30 General Discussion (sailing related) 10 09-19-2007 12:11 PM
