Induction vs electric vs alcohol stove? - SailNet Community
 3Likes
post #1 of 34 Old 11-14-2012 Thread Starter
guitarguy56's Avatar
Ok... so I am remodeling my galley and have the opportunity to take out the old Origo alcohol stove out and put in my choice of stove cooktop... I'm leaning towards the induction cooktops as they are safe (no heat involved) and easy to clean cooktop... most of my cooking will be done while moored or in the slip... I have a portable propane cooktop if need be during voyages... the induction cooktop can also be used while under way since one is 1500 watts and the other is 1300 watts and you can input any wattage between 200-1500 on either of them... they are very efficient and the cooktop is warm to the touch after the pot is removed so it is very safe in my viewpoint actually safer than alcohol or propane... even the regular electric cooktop is unsafe due to the lingering heat of the elements... would this be safe being that it's a magnetic cooktop and might cause electrical interference to the boat's electronics? Am I being too cautious?
Nick
guitarguy56 is offline
post #2 of 34 Old 11-14-2012
chucklesR's Avatar
Re: Induction vs electric vs alcohol stove?
Those are of course only good if you have space for two (one not electric), or a generator, or a large inverter and battery bank.
Add those watt rating up - and consider you only have 30 amps at the pier.
chucklesR is offline
post #3 of 34 Old 11-14-2012 Thread Starter
Yes... I would be only using one cooktop at a time... I have the Honda 2000 watt generator as well... cooking time with these units is under 10 minutes at most... heating water only takes 3 - 4 minutes... so not much to power them up... sure we have 3300 watts at the pier and that's plenty... we're not running all the electrical items at the same time while at the slip... most of my lights on the boat are LED's... only one not LED is at the mast.
post #4 of 34 Old 11-19-2012
Crotchety Old Member
tomperanteau's Avatar
It would work as long as you don't try to use it while out. Or at least if you did, you would have to have a LOT of solar and wind to compensate. Cooking anything on a stove top will take time to heat, and that time will also be draining battery banks, as Chuckles eluded to. If you're only going to use it at the marina, then you will probably be okay.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
post #5 of 34 Old 11-19-2012 Thread Starter
All good points... there are two units, one is 1500 watts and the other is 1300 watts the 1300 watt unit being the smaller one is great for heating liquids, etc... Induction heating is very fast and efficient for heating and warming and can be used almost like a microwave oven to 'warm' foods as opposed to 'cooking' the foods, so it should be excellent when away from the slip... the induction cooktops have variable wattages so they are perfect for conserving electrical needs of the battery... and as mentioned I have the 2000 watt Honda generator for use while away from the slip...
post #6 of 34 Old 11-19-2012
Sounds like you have a plan. As long as you keep an eye on usage you should be fine. My approach comes from planning for an extended amount of time away from the dock, but yours does not, so sounds like you have a good idea of what you need.
S/V Footprints
Youtube
post #7 of 34 Old 12-03-2012
And you can only use pots/pans that are made for induction heating...
CS 36M DIANTHUS
sailordave is offline
post #8 of 34 Old 12-03-2012
Alcohol vs electric is its own issue, but electric vs induction is a no brainer.
Induction is faster, safer, and uses less power.
Greg
Stumble is offline
post #9 of 34 Old 12-06-2012
It is funny, I have three ways of cooking and you didn't list any of them!
I use wood, rarely a microwave, and very rarely white gas.
What are you pretending not to know ?
Please support my
wind_magic is offline
post #10 of 34 Old 12-16-2012
Send a message via Yahoo to woodwrite09
Interesting,.... back in the 80's I had an old Chesapeake-built 32 ft ketch with a small wood stove,.. and freestanding, at that. Not only prepares meals, but makes for a cozy ambiance in the winter. Those were the days, eh? Aside from that, alcohol stoves have always been adequate for my purposes.
woodwrite09 is offline
alcohol stove dubon General Discussion (sailing related) 10 08-06-2012 06:44 PM
alcohol stove questions Kiltmadoc Gear & Maintenance 7 06-23-2010 07:23 AM
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Non-Pressurized Alcohol Stove SEMIJim Gear & Maintenance 32 11-09-2007 10:53 PM
Using an alcohol stove Bermuda30 General Discussion (sailing related) 10 09-19-2007 12:11 PM
