11-20-2012
Re: Why people avoid the South Africa route
Originally Posted by killarney_sailor
BTW, the Agulhas Current is quite close to the shore, usually at around the 200 m depth contour.
But its not very wide.
Those friends found it at 180 meters, at about two knots... So the 5 knots stuff is rubbish. Also very weak of Richards Bay but picks up a bit further south.
OK, Egypt is sensational. But then do you miss out on the animals of southern Africa?
One can do Egypt from the Med using marinas on the north coast of Egypt. Its just getting to the Med is the other way around.
I am sure once more people like Killarney Sailor do the SA rpute it will become more popular and better information will be available to those that follow.
But leaving the Suez Canal right out of it is no problem, it doesnt mean Egypt is off the cruisers plan, just done from the other direction.
Sea Life
Notes on a Circumnavigation: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I write with an iPad and its spell checker changes some words. Beware.
