? Sail from Lake Erie to Florida late August - Page 5 - SailNet Community
 19Likes
post #41 of 60 Old 01-08-2013 Thread Starter
Re: ? Sail from Lake Erie to Florida late August
We will be located in Port Dover, Ont., so that is the north eastern part of Lake Erie. We will likely look at traveling to Lake Ont, to the St Lawrence Seaway, and then to the ICW that goes south from there. DH had hoped to go around the maritimes but we will likely be too late to do that this year. So many questions, so much research! We have some concerns about having to pull the mast, so we are really trying to learn as much as possible about all the routes, and what will be required. I figure for the ol'hands, it's a piece of cake, but for us first timers... it seems like a such a biggy! Actually everything we are planning is a big time life change! I will pm you once I have enough posts that will permit it.
OffWeGo is offline
post #42 of 60 Old 01-08-2013 Thread Starter
This is message #15, as required for pm messaging function.
OffWeGo is offline
post #43 of 60 Old 01-09-2013
Bristol 45.5 - AiniA
Off, from Lake Erie, not going to the Maritimes you have two choices. You can go to Buffalo, take your mast down and do the entire Erie Canal to the Hudson near Albany. Or you can go through the Welland Canal (easy going downhill), do Lake Ontario and end up in Oswego in the SE.corner. Here you take your mast down and go through the short Oswego Canal that joins the Erie. Each of these routes has its advantages. There is a third route, down the St Lawrence to Sorel which is past Montreal and then south through a couple of canals and Lake Champlain to join the Hudson near Albany. This route is much further and mor expensive (have to pay for Welland and Seaway locks) so I would suggest one of the others
BTW, the ICW does not start until the southern end of the Chesaoeake in Virginia.
OffWeGo likes this.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #44 of 60 Old 01-09-2013
(increasing posts to permit private message)
jkfink is offline
post #45 of 60 Old 01-09-2013
OffWeGo, received your PM but don't seem to be able to respond privately until my post-count exceeds 15. John
jkfink is offline
post #46 of 60 Old 01-21-2013
(increasing posting to permit private message)
jkfink is offline
post #47 of 60 Old 02-07-2013
(increasing posts to permit pm)
jkfink is offline
post #48 of 60 Old 02-07-2013
Going south from Sorel, Quebec, was used as one alternative to the closed Erie Canal a couple of years back. In Virginia, the Chesapeake Railway Marina is excellent and not at all expensive on the hard. Liveaboards on the hard, are well accepted.
sony2000 is offline
post #49 of 60 Old 02-07-2013
Do you mean living aboard, while up on stands? I can hardly imagine any living accommodation with greater challenges. Virginia would be a bit more temperate than here, however, in the water the hull can't generally get below freezing. No lowerr limit to the temp of the keel in the air and it acts as a huge heat sink. I imagine the heat would never stop running on cold days. Then, climbing and descending a ladder rountinely in the winter. Ooph. I like all things sailing, but I've found my limit.
I do recall a family friend that lived aboard over the winter, but the boat was kept indoors.
Jeanneau 54DS
Minnewaska is offline
post #50 of 60 Old 02-07-2013
Offwego
Keep in mind that whatever route you choose, when you approach the ocean you will be faced with a different component that doesn't affect the Great Lakes -tides. Be prepared for some challenges initially - no big deal but you have to learn how to use it in your favor.
bljones likes this.
SVTatia is offline
Competent Crew Looking for a Boat in late August in Greece Jimmyl Crew Wanted/Available 0 08-19-2012 03:33 PM
Sailing to Hawaii in late August from Seattle windride Crew Wanted/Available 17 06-05-2012 10:37 AM
A Sail With Courtney- Lake Erie bljones General Discussion (sailing related) 2 08-05-2010 06:55 PM
Event - Lake Erie 30 Mile Sail this summer genglandoh General Discussion (sailing related) 4 03-18-2010 08:28 AM
Desiring to Sail lake Erie sailitaway Crew Wanted/Available 0 03-10-2008 07:19 AM
