Bareboating Catana 47: Guadeloupe, Dominica, Martinique - SailNet Community
post #1 of 7 Old 12-28-2012 Thread Starter
Just finished a 2-week bareboat aboard a Catana 47 catamaran. The boat was very nice (and pretty fast) but the fiberglass seemed thin and the helm layout was not good. If anyone is considering a bareboat in Guadeloupe, Dominica or Martinique feel free to hit us up...we are by no means experts but maybe you can learn from some of our mistakes! Happy sailing...
dmic is offline
post #2 of 7 Old 12-30-2012
Re: Bareboating Catana 47: Guadeloupe, Dominica, Martinique
What bothered you about the helm layout?
REsCAT is offline
post #3 of 7 Old 12-30-2012 Thread Starter
Hi REsCAT, First I should say I am by no means an expert on boat design, or sailing big cats for that matter. Our Catana 47 had a helm on each stern. The autopilot and throttle controls were located on the starboard helm. The chartplotter was inside the salon. From either helm you could only see from approximately zero degrees outward so anytime you navigated a narrow channel, passed another vessel, docked, etc you were completely blind for about a 120 degree arc on the opposite side. I have sailed other layouts (like the Robertson & Caines, Lagoons, etc) that have a single helm elevated to where you can actually see where you're going, and those seem more skipper friendly. I'm sure a more seasoned skipper might do fine with the Catana but I found myself having to post lookouts more often since I couldn't see where I was going (lots of poorly marked fish trap floats, etc) and docking on the port side was very tough since I was blind on that side when operating the throttles at the starboard helm. Also, having to run inside to check the chartplotter was less than ideal.
dmic is offline
post #4 of 7 Old 12-31-2012
Hi Dmic
Thanks for your personal observations of the C47 helm layout, I like to hear other peoples experiences ,thoughts on this subject as I own a Catana 471/2001model which is the model series 1997-2006 previous to the one you chartered.
I would like to address each point you brought up as it relates to my experience and that the two outboard helms are generally a major design feature of Catanas and some other brands.
"The autopilot and throttle controls were located on the starboard helm."
This is true of most dual helm boats unless the commissioning owners request controls on both helms from the factory(Rare) or are added subsequently(still rare). Autopilot controls on both helms are common, (I have them,love them, and are relatively easy to add as compared to throttle/shift linkages). Most charter spec'ed boats can differ greatly from owner/actively cruised versions in terms of level of equipment as you probably are aware.
"Side to" docking typically takes place on the stbd side, the engine controls are there and there is unparalleled sight lines as you probably can agree.
Docking on the port side is more challenging, I do it occasionly,carefully..., but rarely find the need to.
"The chartplotter was inside the salon... having to run inside to check the chartplotter was less than ideal"
Totally agree! but as mentioned above, most owners add a chartplotter to the helm (relatively easy) and your charter company should have added one for the safety,comfort of their clients.
"From either helm you could only see from approximately zero degrees outward so anytime you navigated a narrow channel, passed another vessel, docked, etc you were completely blind for about a 120 degree arc on the opposite side."
This is a major stepback in the evolution of the new generation of Catanas.
I dont Know why Catana or Christophe Barreau the NA allowed this and the dealers/brokers that I talked to agree with me.
With my boat and model series there is good 360 degree (not perfect..) visibility from either helm as the area between the hard top and cabin bulkhead
was kept open for sightlines. I move from helm to helm for channels, other boats etc if more visibility is needed, hence Autopilot controls on both helms.
"I have sailed other layouts (like the Robertson & Caines, Lagoons, etc) that have a single helm elevated to where you can actually see where you're going, and those seem more skipper friendly."
I have not sailed the newest generations of those brands but chartered older ones and did not like the sightlines for sail trim, docking and general "being under sail fun" when I was forced to stay and steer under a hardtop, behind a cabin bulkhead. The helms were more often to the center of the boat, far enough away to prevent effectively assisting in docking or active sail trim.(looking thru a cutout in the hardtop/bimini top to check mainsail trim didnt work for me). But... that location was great for getting food,beers and mingling with cabin folk.
I have been aboard many of the new generations at the boatshows, many have certainly taken unique approaches to helm positions. Some have been executed well and addressed some of the helm position fundamentals but have certainly given up other important desirable fundamentals which I guess brings on the term "Compromise" or no perfect solution.
I cannot accept the logic of putting the mainsail/boom up so high to accomodate flybridge or mid bridge helms! You need a stepladder to reach the boom. (imagine when things go bad...)
I chose a Catana because its number 1 design prority was to sail well. This is reflected in every aspect of its design from helm positions,cockpit layout,dagger boards,carbon fibre rig,hull design etc. This is not true of many other Cat brands.
Please forgive the long winded reply, I would encourage you to take a look at Catanas of my series if a Cat is in your future.
Bob
REsCAT is offline
post #5 of 7 Old 01-01-2013 Thread Starter
Bob, excellent write-up! It sounds like your Catana is very well laid out, I think the addition of an autopilot to the port side would have made a big difference. I also agree with you about boom height on some of the other cats. I have to say, the Catana was superb for crew comfort and general layout.
dmic is offline
post #6 of 7 Old 01-01-2013 Thread Starter
Bob...I meant to ask you, are the dual autopilots linked? In other words, if you set a course on your starboard helm then move to the port helm, can you put the system back on standby? or does each one operate independently?
dmic is offline
post #7 of 7 Old 01-01-2013
Thanks Dmic
I like to think that my boat is well laid out but I still find ways to curse at it
at times... and I could certainly spend every dime I have trying to make it better,
after all cruising boats = money pits right?
I have two complete autopilot systems, including a linear drive,rud ref indicator on each rudder.(1st owner ordered this) I can use either system alone at a time(switched Autopilot A or Autopilot B at the Nav Station)
The autopilot controls at each helm are joined and control whichever autopliot system... A or B is switched on
The boat has mechanical(rack and pinion type steering) so the the two rudders are joined as one.
REsCAT is offline
catana vs. lagoon thegracelist1 Chartering 2 12-10-2012 01:22 PM
Looking for Catana 43 Weltumsegeln Boat Review and Purchase Forum 0 01-14-2008 03:24 AM
Guadeloupe Charter capnphil Chartering 0 02-20-2002 08:53 AM
Catana ericra Boat Review and Purchase Forum 0 10-10-2001 12:05 AM
