An old gravity fed propane furnace from camper installed on boat-good idea or bad - Page 2 - SailNet Community
 3Likes
post #11 of 26 Old 01-16-2013
Re: An old gravity fed propane furnace from camper installed on boat-good idea or bad
Originally Posted by islandskim View Post
I think if I was gonna go propane I would use the old furnace I already have. I like the idea of going gas free though, if anyone has first hand experience with either gravity fed furnace or pellet stove on a boat please post, thanks.
Is it a Force 10 bulkhead heater? There's a HUGE difference between those and the one posted above, esp on the safety front, but also in the effectiveness...
Faster is online now
post #12 of 26 Old 01-16-2013
Maine Sail's Avatar
If your boat is insured you should always consider what the ramifications of installing non-marine approved or compliant LPG equipment means. I had to remove an "on-demand" water heater sold and misleadingly marketed as a "marine unit" out last spring. It did not meet any of the applicable marine safety standards even though the owner believed it did due to misleading marketing. It did not pass the insurance survey and the owner had a choice lose insurance or keep the on-demand water heater....
Among other things to be marine compliant the heater needs be vented and also be sealed combustion (not taking combustion air from the cabin). It also can not have a standing pilot light.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 26 Old 01-16-2013
Jiminri's Avatar
I had to remove an "on-demand" water heater sold and misleadingly marketed as a "marine unit" out last spring. It did not meet any of the applicable marine safety standards even though the owner believed it did due to misleading marketing. It did not pass the insurance survey and the owner had a choice lose insurance or keep the on-demand water heater.....
Main Sail, can I ask the brand/model of the water heater you had to remove?
Jiminri is offline
post #14 of 26 Old 01-16-2013
Maine Sail's Avatar
Excel..
______
post #15 of 26 Old 01-17-2013
Maine Sail, just noticed your link. Found that site via search this summer and refered to it often getting Stella seaworthy. The photos and step by step were/are very helpful. Thank You THANK YOU
1976 Ranger 28
18hp Universal
Please do what you like, just don't do it here.
Stella's crew is offline
post #16 of 26 Old 01-18-2013
Sundance 23
carl762's Avatar
Gravity simply means no fan.,
Ah!!! Thanks.
Ya, can't get enough of Maine Sail's information. Started with the butyl tape thread.
Water is Life
carl762 is offline
post #17 of 26 Old 01-18-2013
"Gravity simply means no fan., "
Damn, I've got a gravity-fed campfire and never knew it!
hellosailor is offline
post #18 of 26 Old 01-18-2013
Dirt Free
boatpoker's Avatar
any ideas? I was thinking it might not work or be dangerous due to wave movement?
also-
Anyone tried using a small pellet stove on a boat?
any advice is greatly appreciated.
chris from Canada
Propane on a boat is perfectly safe if done properly. If you do not know whats required to accomplish that don't even start.
If you intend to pursue propane send me a pm with an email address and I'll send you the standards or you can take a look at Safe Boat Propane Installations
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #19 of 26 Old 01-23-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
propane scares me. It is just as bad as gasoline for sitting in the bilges if you get a leak.. and just as likely to blow your boat skyhigh if it ignites.
I like the kerosine and even better, the diesel stoves.. especially if you have a diesel engine already aboard
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #20 of 26 Old 01-23-2013
One of None
deniseO30's Avatar
Guess no one has ever seen a diesel "explosion" It can happen in a heater that's hot. and someone tries to relight while the fuel is still being gasified by the hot burner. More often with diesel they will belch soot, so much that every surface will be coated.
With all the safety devices available and common sense. and a diesel engine boat. someone would almost have to want to blow up their boat!
My last project!
deniseO30 is offline
Tags
heating propane furnace
Seemed Like a Good Idea... Squidd Gear & Maintenance 11 04-09-2012 07:42 PM
Letting a friend use my boat for charter -- good idea? Bene505 General Discussion (sailing related) 18 09-02-2011 11:31 AM
in a storm... good or bad idea to... jobi Learning to Sail 14 07-05-2010 04:58 PM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 07:19 AM
a good food idea Tegolin Provisioning 1 06-25-2005 07:47 PM
