An old gravity fed propane furnace from camper installed on boat-good idea or bad - Page 3 - SailNet Community
 3Likes
post #21 of 26 Old 01-23-2013
bljones's Avatar
Re: An old gravity fed propane furnace from camper installed on boat-good idea or bad
If you're looking to keep your costs down, try a Tiny Tot stove.
Fatsco Stoves
It's not as efficient as a pellet stove, doesn't self feed, etc., but it's a third of the cost of a Dickinson stove, can be used as a small cookstove, and the fuel is free.
It's 5 o'clock somewhere:
bljones is offline
post #22 of 26 Old 01-23-2013
bl, isn't that getting real close to the same thing as two industrial-sized tin cans? A little work but voila $300 cheaper still. ;-)
This is an "invigorating" week for anyone living aboard in the Northeast.
hellosailor is offline
post #23 of 26 Old 01-23-2013
bljones's Avatar
Hello,
The size is close to a cafeteria kitchen-sized can of stewed tomatoes, but the fatsco stove bodies are made of stainless steel.
Y'know, i thought about trying to build a decent small low-buck boat woodstove that I wouldn't have to rebuild every season. But, by the time you cost out SS sheet, cut it, form it (the sheer number of blades you go through cutting stainless is damn near cost prohibitive), get a shop to weld it together, etc., you're at or above the cost of a fastco stove, without figuring in your own labour.
Now, if I already owned a tig welder and plasma cutter, then the cost and time drops enough to make it worth considering.
or I could cut down some thick wall steel tube, get it powder coated, etc., etc., ...
It's still hard to beat a Fatsco.
bljones is offline
post #24 of 26 Old 01-24-2013
Asleep at the wheel
jimgo's Avatar
Are the Tiny Tot heaters/stoves wood burning?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #25 of 26 Old 01-24-2013
bljones's Avatar
Yes, they are solid fuel stoves.
bljones is offline
post #26 of 26 Old 01-24-2013
norahs arc's Avatar
Re camper propane appliances of any kind on board - NO! NO! NO!
Use propane products designed for marine use only on board. Ther are major differences in the safety features and materiels used. RV, camping and home products are not safe or suitable on boats.
norahs arc is offline
Tags
heating propane furnace
Seemed Like a Good Idea... Squidd Gear & Maintenance 11 04-09-2012 08:42 PM
Letting a friend use my boat for charter -- good idea? Bene505 General Discussion (sailing related) 18 09-02-2011 12:31 PM
in a storm... good or bad idea to... jobi Learning to Sail 14 07-05-2010 05:58 PM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 08:19 AM
a good food idea Tegolin Provisioning 1 06-25-2005 08:47 PM
