An old gravity fed propane furnace from camper installed on boat-good idea or bad - SailNet Community
 3Likes
post #1 of 26 Old 01-16-2013 Thread Starter
any ideas? I was thinking it might not work or be dangerous due to wave movement?
also-
Anyone tried using a small pellet stove on a boat?
any advice is greatly appreciated.
chris from Canada
islandskim is offline
post #2 of 26 Old 01-16-2013
Skipper Jer's Avatar
Re: An old gravity fed propane furnace from camper installed on boat-good idea or bad
Hi islandskim. I see that the above post is your first so you are new to SailNet. Let me be the first to welcome you and let you know we are not elitists.
I'm not sure why gravity needs to be used to supply propane to the furnace since the propane is under pressure and that will move the gas to the burner.
Skipper Jer is offline
post #3 of 26 Old 01-16-2013
If it is vented properly, installed properly, and the fuel is available to you, anything goes. I'm also curious how you would "gravity feed" propane, since it flows by pressure, not gravity.
islandskim likes this.
hellosailor is offline
post #4 of 26 Old 01-16-2013
Sundance 23
carl762's Avatar
I think the pellet stove would be a great idea, for heat anyway. I don't get the gravity fed propane thing. I use a propane swing-type stove in the cabin and have a propane BBQ on the back rail. Both work great, and I get great mileage from my propane.
Welcome to Sailnet.
Water is Life
carl762 is offline
post #5 of 26 Old 01-16-2013
One of None
deniseO30's Avatar
Gravity air convection. (no fan) like a typical camper has. Should work, but rust out prematurely since it's steel and painted steel. vent pipe would be quite large because it's natural draft.
My last project!
deniseO30 is offline
post #6 of 26 Old 01-16-2013
Lake Superior Sailor's Avatar
Denise: right on as usual, hard to beat that girl in her field! Always impressed..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #7 of 26 Old 01-16-2013
One of None
deniseO30's Avatar
Thanks Dale!
My last project!
post #8 of 26 Old 01-16-2013 Thread Starter
thanks for the posts guys. Gravity simply means no fan., Im curious though if the flame would go out while travelling in rough weather. I have found some small pellet stoves online around 3000 new, so don;t think I'll be going down that rout anytime soon. For some reason they don't have those in Canada (Yet). I have seen the "little gnome" pellet stove for example can run on a 12v fan, again not sure if wave action would affect the operation...??? anyone??
post #9 of 26 Old 01-16-2013
The Dickenson Newport is a great little propane fireplace, two sizes (9,000 and 12,000 BTU) we have the smaller on our 34 footer, used the larger on our last boat, a 40 footer. Fully vented, outside air supply, sealed combustion chamber.. really safe and good ambiance due to the glass front and visible flame.
DICKINSON NEWPORT PROPANE HEATER - P9000 Binnacle.com
Under $1K AND it comes with all necessary flue pipe, deck fitting, etc. All you need to add is the fuel line. Only complaint is a rather noisy fan..
Faster is offline
post #10 of 26 Old 01-16-2013 Thread Starter
I think if I was gonna go propane I would use the old furnace I already have. I like the idea of going gas free though, if anyone has first hand experience with either gravity fed furnace or pellet stove on a boat please post, thanks.
Tags
heating propane furnace
Seemed Like a Good Idea... Squidd Gear & Maintenance 11 04-09-2012 07:42 PM
Letting a friend use my boat for charter -- good idea? Bene505 General Discussion (sailing related) 18 09-02-2011 11:31 AM
in a storm... good or bad idea to... jobi Learning to Sail 14 07-05-2010 04:58 PM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 07:19 AM
a good food idea Tegolin Provisioning 1 06-25-2005 07:47 PM
