01-18-2013
formerly posting as eryka
Re: Heat Help
Those reverse cycle systems cost $2K and up. Dockside, at your home marina, a space heater from the local hardware store is $50. Which would you rather put the wear and tear on (and ultimately have to replace?) We use one of those oil-filled guys that looks like an old-fashioned radiator - develops lower temp than a regular space heater, and therefore less problematic to leave. We also have a Webasto AirTop 2000 for when we're away from the dock.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. still has some glitches to be worked out. Until then, I'm posting at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ! And a new project: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
