Issues with Heating in Annapolis, MD - Page 2 - SailNet Community
 26Likes
post #11 of 39 Old 01-25-2013
Tim R.'s Avatar
Re: Issues with Heating in Annapolis, MD
Knowing specifically what system you have is the first step to troubleshooting.
We have a Mermaid 16000btu reverse cycle unit and we used it right up to new years day. The water was in the mid 40s and it continued to pump out warm air and maintain 65° in our cabin although it cycled every 10 minuets. It does not have a supplemental heating coil. We also have an ITU Hurricane II diesel hydronic furnace for the cold days like we are having now.
The other thing you need to properly troubleshoot is an infrared thermometer.
But you must ensure that those through-hulls are not frozen. That can be very dangerous. The fittings can rupture from the expanding ice in them and cause leaks when your boat heels and they submerge.
BTW, this could also simply be a pump relay that is not functioning. We had similar issues with our reverse cycle relay. A good bump would activate it until I could replace it.
Kraden313 likes this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #12 of 39 Old 01-25-2013
formerly posting as eryka
wingNwing's Avatar
Hey Kraden, stop by our boat for a cup of hot cocoa and a tour - it's probably about 70 in here. We have diesel heat plus a couple of electric space heaters. We'd be glad to loan you a space heater until you get sorted. We could also come by this afternoon and help you verify what type of heat you currently have.
kd3pc, deniseO30, jimgo and 2 others like this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #13 of 39 Old 01-25-2013
Abysmally Stupid
One thing we did when we lived on our boat during winter in Annapolis was to wire two electrical outlets from the 30A circuit that is decicated to the Aircondition.
One outlet in the aft cabin, one in the salon.
That way we utiilized all 30A shorepower coming in to the 30A aircon circuit to run two large oil filled heaters, while still having the 30A on the "house circuit" available to run other electricals (TV, toaster, coffe maker etc) on the boat.
You should be able to do the same thing since your boat has two 30A circuits and dual shore power inlets.
If you cannot do the install yourself, a marine electricain (or general handyman) should be able to do this inexpensively.
The two oil heaters kept our boat warm during the entire winter, we never saw less than 66F in the boat regardless of outside temp.
This modification together with a dehumidifier, a froli systemunder the matress and electric blanket was the things that made our winter relatively comfortable.
Other than that, moving into a house might be the best solution ;-)
jorgenl is online now
post #14 of 39 Old 01-25-2013
My understanding of heat pump/ac type units that lack additional resistive heating elements is the most efficent units can only heat or cool approximately 30 degrees from ambient.
So on a 100 degree day, ac is only going to get you down to about 70 degrees. Conversely, if its 20 outside, about 50 is all the "heat" you can expect from a heat pump unit. You are gonna need some alternate means of heating your boat when the temps get below about 35 degrees.
Home heat pump units have a "second stage" to take over when the heat pump alone is not enough, but marine units lack this feature. The second stage is usually electric resistive elements.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is online now
post #15 of 39 Old 01-25-2013 Thread Starter
Kraden313's Avatar
Bubblehead thanks for the information. The more I read these responses and the more people that I talk to it actually just sounds like the water is just too cold and our unit just can't keep up. Makes sense I guess. I believe we actually have a 50 and a 30 amp Shore Power. I have a space heater running now....but it's just not doing much. Husband will be home shortly and is going to stop by Lowes and pick up a different kind of heater. Sooooo much to learn on this boat. But it's fun....and challenging. Thank goodness for warmer temps next week. WingNWing......would love to chat with you more about this since you are right here. I think you have my number..if not let me know and I can send it to you through gmail. THANKS!!!!!!!
Kraden313 is offline
post #16 of 39 Old 01-25-2013 Thread Starter
Kraden313's Avatar
Also, one other thing...I have gotten a few "Private Messages" about this and apparently since I just signed up today, I am unable to reply to those messages. I can actually see part of the message on my iPhone, but again, cannot reply until I have been a member for at least 7 days.....well that's the message I am getting anyways when I try and open the message. I just don't want you to think I am ignoring you. Thanks again
post #17 of 39 Old 01-25-2013
Moderator
Jeff_H's Avatar
That may be in part be true but it is not the problem that you are having. If that were the cause of your problem, the unit would be running continuously and you would have a continuous flow of water at your through hulls. The clue to what is wrong is that you do not have water flowing.
But even if your system were running it may not be able to keep up since boats are insulated and water to fiberglass is a pretty efficient heat exchanger. But even so, a water media heat pump should work reasonably well even when the water is close to freezing.
You should shut that system down until you determine whether the circulator pump is working right, and whether you have a burst hose or through hull. You also should check your bilge for rising water.
Tempest likes this.
Jeff_H is online now
post #18 of 39 Old 01-25-2013
Tim R.'s Avatar
Actually some marine units do have resistive elements as an option. I can get one for mine if I like.
Some other notes. A marine unit typically uses water as it's medium so the air temp has very little to do with how much heating or cooling one can generate. It does affect how much the unit cycles though.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #19 of 39 Old 01-25-2013
Geoff54's Avatar
Kraden
Go over to one of the "not serious" threads and makes some posts so you can get your PMs. Here are a couple:
The place to make junk post so you dont clutter others
http://www.sailnet.com/forums/off-to...ong-chain.html
Geoff54 is offline
post #20 of 39 Old 01-25-2013 Thread Starter
Kraden313's Avatar
Jeff that is correct that the water was not coming out of the thru hulls last night or early this morning. And when you mentioned it might possibly be frozen on the inside, that was my initial thought. I actually turned the unit off this morning after I made my initial post and got a few replies. I kept it off for a few hours and around noon I turned it back on and went outside to see if we had water flow. We actually did start to have flow coming out of the back and front hulls again. So I left it on, anxiously thinking we were getting ready to have some heat again; however, the temp only got to 50 and would not go any higher. So I just turned it off again and we are looking for some oil heaters to use in the meantime. Next week when we have some warmer temperatures it will be interesting to get the units turned back on and see what happens. Thanks for the heads up on checking the bilge.....I didn't even think about that earlier, and I just checked it and all is good....no water. Thanks again for all your thoughts and posts. Very much appreciated for sure.
chef2sail and wingNwing like this.
Heating Your Boat CapnBones Gear & Maintenance 52 08-12-2014 09:56 PM
Reverse air not heating well LakePirate Gear & Maintenance 12 03-15-2010 11:03 AM
Around Annapolis: May Day brings out flower competitions - Annapolis Capital NewsReader News Feeds 0 04-29-2007 11:15 AM
heating and conditioning ustunkal Living Aboard 5 07-13-2006 03:09 PM
Heating Question pirateofcapeann Living Aboard 3 12-14-2002 02:12 PM
