Windows7 as a Wifi hotspot - SailNet Community
post #1 of 8 Old 03-12-2013 Thread Starter
Question Windows7 as a Wifi hotspot
Hi
Can any one tell me how to make my laptop a hot spot. I am not computer savy so I don't understand the way it's printed online. I have an external amplified antenna and I can pick up wifi but the wife's Kindle can not. (happy wife, Happy life) ;O) thanks
Steve Pike is offline
post #2 of 8 Old 03-12-2013
I'm not sure you can if that wifi is what's giving you an Internet connection. Afaik you can share a wired Internet connection via wifi and a wifi connection via wired connections but not a wifi connection via wifi.
br3nt is offline
post #3 of 8 Old 03-12-2013
Re: Windows7 as a Wifi hotspot
Connectify Hotspot - The Wi-Fi Software Router for Windows PCs
This might do it.
It sounds like you are using Wifi on your PC to connect to the internet via a distant Wifi router that your wife's Kindle can't reach. Normally a hot spot uses a different connection (cellular or hard wired) to reach the internet and then only uses Wifi to feed local devices. You're trying to use the one same Wifi connection to accomplish both, and that may prove problematic.
hellosailor is offline
post #4 of 8 Old 03-12-2013
Remember you're a womble
PaulinVictoria's Avatar
The Connectify thing should do the trick.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 8 Old 03-14-2013 Thread Starter
Unhappy Re: Windows7 as a Wifi hotspot
well...sounded good... gave it a try.... it caused to many conflicts and I uninstalled it......thanks though it was worth a try.
Oh ya ... I downloaded free version. cant afford paid one.
post #6 of 8 Old 03-22-2013
if you tinker around with the connectify it should work fine on windows7...i currently am using it to provide my girls iPad with the wifi signal i am picking up on the long range antenna....weve actually been using it with great success in the bahamas for a few months now....maybe uninstall/reinstall....every once and a while we have had to do that....oh and it is the free version
Dolby is offline
post #7 of 8 Old 03-22-2013
Windows comes with a utility called Internet Connection Sharing. If you are bringing the data in from the amplified antenna with Cat5 cable you could connect that to the Lan adaptor of the laptop then use the wireless adaptor to share the connection.
mitchbrown is offline
post #8 of 8 Old 03-22-2013
4KSB driver.
SHNOOL's Avatar
Set up a computer-to-computer (ad hoc) network
Is this not working?
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
Virgin Mobile MiFi 2200 Prepaid Mobile Hotspot TakeFive General Discussion (sailing related) 8 06-20-2012 06:29 PM
WiFi brokesailor Gear & Maintenance 4 12-02-2011 10:39 AM
Wifi jrd22 Gear & Maintenance 42 06-17-2009 12:51 PM
WiFi firstafair General Discussion (sailing related) 4 11-17-2007 02:34 PM
Wifi mallo Gear & Maintenance 3 03-21-2007 10:09 AM
