do you carry an acoustic Guitar? - SailNet Community
 22Likes
post #1 of 122 Old 03-25-2013 Thread Starter
if so, what do you do to maintain the proper Humidity levels to ensure that it does not swell/shrink and have major issues?
vikingthunder is offline
post #2 of 122 Old 03-25-2013
Re: do you carry an acoustic Guitar?
I'd suggest that if you're very concerned about those types of things that you get yourself a less expensive guitar for the boat.
I've never noticed an issue, though we have only kept the guitar on board during the summer months. But I'm not a virtuoso and don't have expensive guitars...
Faster is offline
post #3 of 122 Old 03-25-2013
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
Hi, I'm a member here, but my day job is in the music industry.
I work for a company that makes these... Among many other products. Not trying to advertise, but to help out.
http://www.amazon.com/Planet-Humidipak-Automatic-Humidity-Control/dp/B000OMG0KI
Normally, you'll have to worry about humid conditions. It's best to keep your instrument in a case when you're not playing it, and try to control the environment in the case.
Humidipak will regulate in either direction. However, in dry conditions also use another moisture adding device like a Guitar Humidifier so the pak doesn't dry out.
If its really wet conditions, (above 70% day after day) use a "dried out" humidipak in your case which will absorb moisture.
Again, keeping the guitar in a case when not in use will really help. Also, go to your local shop and learn how to make a truss rod adjustment because the neck will move. It's perfectly normal, I adjust many of my instruments every year to get the action right. It's routine and if you can do basic boat maintenance you can do basic guitar maintenance. Wood moves with trends in humidity...
Finally, consider coated strings to minimize corrosion. This is vital on a boat. My company makes the EXP line of strings but there are others out there as well like Elixir.
If you have any questions, don't hesitate to ask. I know Cruisingdad has a guitar on board, perhaps he wants to share his experience.
Good luck, keep playing...!!!
Craig
D'Addario and Co.
jerryrlitton likes this.
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #4 of 122 Old 03-25-2013 Thread Starter
My Guitar came with an Ameritage case with their humidity abatement system, but not sure if it will keep up with the extremes of humidity you get on a boat.
I have used D'addario Phosphor bronze true mediums for awhile now, and love them. I did not like the Elixer strings, they felt like something was on them. Do the D'addario coated strings feel better?
I am comfortable with Truss rod adjustment, as I had to do it when I went up to mediums from lights. Just curious about humidity and weather and their affects on strings and wood.
post #5 of 122 Old 03-25-2013
craigtoo's Avatar
Hi VT,
I can't speak to Ameritage's humidity abatement system I'm not familiar with it. (I'm an operations guy really..) I agree with your gut feel that there will be some serious swings of humidity on a boat. Definitely get an "in case hygrometer" so you can keep track. Planet Waves (a division of my company) as well as others make them. There's not a company on earth that will tell you that their humidity control system is bullet proof. A boat is a tough environment for a wooden instrument, but many have done it. It's very important to check your instrument regularly.
I'm glad you like our strings. The EXP line as compared to the Elixir's are generally considered to be more natural sounding and feeling, however both strings are coated and will feel different than the PB Strings (EJ17 perhaps?) that you like. D'Addario coats the wrap wire before winding but uses the same design as what you're used to, while Elixir coats the string after winding. The material properties of the coatings are completely different. Elixir makes a good product, damn good, just different than ours. It's really a preference thing. They sound and feel different.
Happy to answer any more questions to the best of my ability.
Craig
D'Addario and Co.
Avid sailor and player on the water....!
Capt. Gary Randall likes this.
-C2
Meet me at the
I love
craigtoo is offline
post #6 of 122 Old 03-25-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
I use EXP's on my electrics. Sadly, they will not go along on the boat. I'll try a set on the acoustics and see how they do.
Not all adjustments are via the truss rod; just as not all twinges in the guitar are not in the neck. Humidity and swelling; or lack of, can cause the top to expand/shrink and arch or pop the bridge. BTDT!
I even went so far as to look into the composites. Seems that I can get a decent spruce top bear a dozen times over for the price. Only one close to realistic was the Asian Martin all-formica (high pressure laminate...yeah!) wit the lam neck for near $700...still too high$$ fr my tastes for a boat picker
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #7 of 122 Old 03-25-2013
Capt. Gary Randall's Avatar
I carry my saxophones with me on my own boat, or usually one alto on deliveries. I keep them in the case with a bag of silica or rice if I don't have silica. That seems to work okay they are always wet when you put them up. captg
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
post #8 of 122 Old 03-28-2013
Sundance 23
carl762's Avatar
Sold a fellow boater who lives full time on his my Fender Acoustic with a very nice hard case. He opened up the case to play one day and the whole top of the guitar body and neck were wet. He moved it out to storage and brings it down to play. Shame.
I bring my Takamine acoustic down to the boat, but take it home, after hearing of the above.
I had a small electric travel guitar that I kept on the boat full time last year. It fared well for months, until one day I noticed the bridge starting to pop out of the body. Still need to fix her and bring her back down.
I would be willing to try out moisture prevention devices and media for the acoustic.
I do some of my best picking on the boat.
Water is Life
carl762 is offline
post #9 of 122 Old 03-28-2013
Some do more than that: They are carried by a guitar
post #10 of 122 Old 03-28-2013
guitarguy56's Avatar
No problem with my acoustic guitar yet! I have the Cordoba C5 guitar and it is in it's gig bag... the guitar has never had a problem or issues with the neck or having to constantly retune and I've had it 9 months here in Seattle. I do put the guitar in a plastic bag and seal tight when I'm away from the boat for any period of time exceeding one week... other than that I think it's a non issue just don't bring your more 'fine' guitars into the boat... my biggest fear is banging the guitar against rails, seats, bulkheads, etc.... so far I haven't gotten a single dent or scratch due to it being in the boat so I'm very happy at this time.
Nick
guitarguy56 is offline
Any guitar players aboard? flylikeabeagle herSailNet 32 03-16-2014 08:23 PM
Acoustic Insulation for engine room? T37Chef General Discussion (sailing related) 30 03-31-2013 08:52 PM
Guitar or Other Instrument Players Cruisingdad General Discussion (sailing related) 64 05-12-2012 10:57 AM
Vintage guitar for trade Jace2 SailNet FAQ 0 12-04-2009 12:32 PM
