12v Fans......? - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 05-13-2013
bristol299bob's Avatar
Re: 12v Fans......?
I've got a few Hella Fans. They are quiet, adjustable (speed and direction) and move decent air.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #12 of 18 Old 05-13-2013
bigdogandy's Avatar
Dock
Re: 12v Fans......?
Originally Posted by kentobin View Post
My vote goes for the Caframo Sirocco Model 807 as it moves a lot of air and has been trouble free for 3 years now.
I also have two Caframo Bora Model 748 and they don't move any where near as much air so I ended up using the Bora in the forward berth where I don't like a lot of air movement when I'm sleeping and don't need it.
S/V Keith, 1978 Rafiki 37 ft cutter.
+1 on the Scirocco fans.....I replaced an older Bora with a Scirocco recently and it is much quieter, moves more air at high volume, and has good adjustment from high to low. Plus there is a staged timer built-in, so I can leave it on for some background noise and breeze as I fall asleep and it will turn itself off after an hour or so.
JimMcGee likes this.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #13 of 18 Old 05-14-2013
fryewe's Avatar
Re: 12v Fans......?
Caframo is tops. And the 747 model moves more air per milliamp than any other model I've found. 400 milliamps per fan on high speed and 200 on low (but who uses low speed?). And they move more air than Scirocco or any other model. West Marine stores sometimes have a display that allows you to test the various 12V fans they sell. I ran them all and the 747 was clearly the best. One problem with them is that the suction cup provided with the fan is useless and won't stick on any surface in the boat. However when I emailed them they sent me three suction cups from older models that did work. Said they were working on a solution. West Marine sells clips that fit the fans if that is a reasonable method of making the fans portable on your boat. The fans also come with mounts for permanently mounting them that are good mounts.
The 747 is also a quiet fan.
fryewe is offline
post #14 of 18 Old 05-14-2013
Re: 12v Fans......?
In my local Fry's electronics they had a nice selecton of 12v computer fans that were composite and cheap! like $12. My next fan is gonna be something easily replaceable and a home-made mount.
xymotic is offline
post #15 of 18 Old 05-14-2013 Thread Starter
F15EWSO's Avatar
Re: 12v Fans......?
Thanks for the inputs, seems that having to go with the higher cost "marine" option just pays off. Looking at other fans at 1/3 the price it seems you just get a mixed bag of fans made in china with noise, reliability levels all over the map.
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #16 of 18 Old 05-14-2013
Re: 12v Fans......?
Just came across an interesting article on balancing fan blades with a strobe light. Looks like another boat project.
Apparently I don't have enough posts to leave the link so just google:
Notes on using a stroboscope to help balance fan blades: (By John McComas)
kentobin is offline
post #17 of 18 Old 05-14-2013
chef2sail's Avatar
Re: 12v Fans......?
I have 3 Caframo Sirocco Fans. They are quiet energy efficient and move a ton of air/
They also get an incredible amount of dust on them.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #18 of 18 Old 05-15-2013
TQA
Bombay Explorer 44
TQA's Avatar
Re: 12v Fans......?
Yet another vote for Caframo. I have 4 of the two speed compacts. On slow they are quiet enough to use while you are sleeping.
Worth carrying spare blades as they do fail sometimes.
TQA is offline
Cabin Fans fireman181 Gear & Maintenance 18 10-25-2012 01:55 PM
cabin fans noelani General Discussion (sailing related) 18 07-03-2012 09:02 AM
quiet 12v fans? jimmalkin Gear & Maintenance 6 10-05-2007 11:23 PM
12v Fans for ports halyardz Gear & Maintenance 2 12-30-2001 06:14 PM
