Water purification - Page 2 - SailNet Community
post #11 of 19 Old 05-15-2013
outbound's Avatar
Re: Water purification
Sounds like another excuse to wash in water but drink beer ( grin). On more serious note. being politically incorrect carry bottle water for drinking when ever in area concerned about purity. Next pass on the boat is to put in reverse osmosis when the kitty goes back up. Still use filters on in and out.At least take out particulate matter.
s/v Hippocampus
Outbound 46
outbound is offline
post #12 of 19 Old 05-15-2013
i clean the water tanks every year with a heavy dose of chlorine and a brush (very good access to the inside). i add a bit of chlorine to the tank whenever i take on water. i also have a rec vehicle type filter between the water pump and the faucets. cost about $20 at any rv place - also seen them at walmart.
but the admiral still prefers bottled water. so for drinking purposes, there's bottled water stored all over the damned place.
otoh, if you are truly concerned about the purity of your water, there is only one method that is capable of producing it; steam distillation. suprisingly, there are some reasonably priced units available that will make one or two gallons at a time, either on your stovetop or 110 ac. google around if you're interested...
onestepcsy37 is offline
post #13 of 19 Old 05-16-2013
tommays's Avatar
The coconut carbon is a necessary evil that causes as many problems as it solves in that its a bit of a bacteria breeding bed
Officially are final microbial filters at work are .2 micron
To be really clean we go 5 micron string filter/ coconut carbon bed/5 micron string filter to remove carbon fines /stuff that does not matter/ ABSOLUTE 5 micron filters/ABSOLUTE.2 micron filters
Of great interest right now is the units like camelbak portable UV unit for camping Treats 80 cycles or 16 gallons with each charge
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 19 Old 05-17-2013
outbound's Avatar
Still think it makes sense as consumables are used up by volume to filter at 5-10microns going in but filter differentially going out. Needs for wash/rinse/cooking and potable water are all different. One can make the case for a variation of a "day tank" like the big boats do for fuel. Personally filter to 5microns. While coastal ( this year) will use bottled water and look into the camping devices. Next year (if funds) allow will add reverse osmosis for potable water. My tanks are GRP with a epoxy liner. Will be rinsed with clean water and baking soda. then rinsed again with just fresh. then periodically bleach shock and rinsed. need to run through all tubing and faucets to get fresh tasting water.
s/v Hippocampus
Outbound 46
outbound is offline
post #15 of 19 Old 05-17-2013
johnnyquest37's Avatar
Add chlorine to your water. No more than 4mg/l. Filters are good for taking particualte matter out of the water, but that doesn't strain out the little critters. By the way, tap water in the US is treated with cholire.
Water Quality and Health Council - Drinking Water Chlorination, Water Disinfection, and Safe Water
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #16 of 19 Old 05-17-2013
outbound's Avatar
On the hard we're on a well. No Chlorine. Filter system. Lawns/shower/toilets etc. filtered to one degree. all in house faucets UV and fine filtered. Stomach has very low pH. Don't use chlorine in system. Back flush periodically. Haven't got sick yet. Salt pellets cheap. filters more money and less flow as finest goes up. Would like to approximate on the boat.
s/v Hippocampus
Outbound 46
outbound is offline
post #17 of 19 Old 05-17-2013
Water from a reverse osmosis watermaker should not need additional treatment, unless it is stored for while. Exposure to air or the container could allow microbes to contaminate the water. Tap water in the US is already treated with chlorine. If you are concerned about microbes in your water, no "filtering" is going to help. Boil the water to kill the microbes or use chlorine. Eight to 16 drops per gallon of houshold bleach will work. There are other bleach products you can use that FDA approved for human consumption.
There are many studies that prove the effacacy of chlorine as a sterlizing agent in water. It has also proven to be safe when used in low dosages. On the other hand, just a few microbes can kill you, and do kill thousands of people every day.
[/B]S/V Wind Orchid
Annapolis, MD
post #18 of 19 Old 05-17-2013
outbound's Avatar
Agree a few microbes can kill you but unless you are getting your water from contaminated sources in the US not much of a concern. Infectious diarrhea remains a leading cause of childhood death worldwide but fairly rare here. Well water with clean pipes safe on land. Marina water should be looked at for source and plumbing but unusual to be a problem in US. Would be not as concerned especially if your water is used as sitting water more of a concern. You have billions upon billions of microbes on you and in you as you read this post including many potential pathogens. Still, proper handling of potable water is an issue of all of us on or off the boat. If your water sits by all means add bleach.
s/v Hippocampus
Outbound 46
outbound is offline
post #19 of 19 Old 05-17-2013
chucklesR's Avatar
I think what Knothead is trying to say here is yep, this one.
chucklesR is offline
2 boaters in water after sailboat tips off water off Madeira Beach - ABC ... - ABC Ac NewsReader News Feeds 0 05-12-2013 10:00 PM
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 11:03 AM
water purification QuickMick Gear & Maintenance 8 09-22-2010 10:31 AM
Water Purification hsilvermanmdjd Cruising & Liveaboard Forum 24 10-10-2006 10:48 AM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
