Safety netting for kids - SailNet Community
Cruising and Sailing with Children All things sailing and kids related, from safety to life aboard.
 7Likes
post #1 of 22 Old 08-19-2012 Thread Starter
boating2go's Avatar
We are thinking of putting up safety nets for when our 4 year old granddaughter is aboard. Anyone have any experience with safety nets? Are they effective? We didn't have to for the older ones but this one is completely different and into everything, so we are worried about her.
boating2go is offline
post #2 of 22 Old 08-19-2012
Old as Dirt!
svHyLyte's Avatar
Re: Safety netting for kids
We used netting on our boat from the time my daughter was an infant until she was about 7-8 years old. The netting extended from the pushpit to the bow-pulpit on either side of the yacht and was secured to the upper life-lines with a continuous line wrapped over the top life-line and through the netting between stanchions. The bottom of the netting was secured by 1/4" Dia bungee cords that were stretched between the stanchions, passing in-and out of each square of the mesh on the bottom edges and attached to each stanchion base with clove hitches. With the bungee cords, one could raise the netting enough to pass lines underneath without difficulty but the munchkin couldn't get under the net. This arrangement kept child and toys and various gear aboard the yacht without any difficulties and gave us some peace of mind when she was on deck (even though she was also tethered to the yacht whenever she was on deck).
FWIW...
boating2go, elspru and TheWollard like this.
svHyLyte is offline
post #3 of 22 Old 08-19-2012
I like wire ties for top because they are easy to cut away if needed and easy to refresh. Very strong and cheap. Just an option.
ParadiseParrot is offline
post #4 of 22 Old 08-19-2012 Thread Starter
boating2go's Avatar
I like the wire ties idea, that was what I was thinking. The bungee cord for the bottom is a great idea. Thanks for the suggestions so far.
post #5 of 22 Old 08-19-2012
Senior Cruiser
sea_hunter's Avatar
Not recommended, kids, dogs et al can go right over the top. Use instead a recommended tether/jackline. The bungee idea sounds good, but remember, does it take more or less than 20lbs to stretch, and what's your g-daughter's weight.
sea_hunter is offline
post #6 of 22 Old 08-19-2012
poopdeckpappy's Avatar
Here's a opinon; I just did a 40 footer and if you're going to do it do it right.
That mean weaving the top lifeline threw the netting and using a taught line at the bottom, if that means adding hardware, add hardware.
The use of zipties should only be used when laying it out, not as a final fastener
This 40 footer had a solid SS top rail and I used a guilt stitch and 300 ft of 1/8" black tuna line to secure the netting at the top and 200 SS fasteners and 100 ft of 1/8" white tuna line as a taught line.
So you can make it look fantastic and enhance the look if you choose
Like I said, that was only a opinon
Cruisingdad likes this.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #7 of 22 Old 08-20-2012
Senior Smart Aleck
jameswilson29's Avatar
I installed safety netting with line ties as an additional precaution for my 2 year old son, who always wears a harness. It seems to have worked fine. Although it may not ultimately prevent a hard fall overboard, it would certainly slow down a fall and provide an additional hand hold.
I have also been very pleased with its effectiveness in keeping my hank-on jibs on the foredeck when dousing them singlehanded. Now, I would install one on any future boat simply for the ease of sail handing.
IslanderGuy likes this.
jameswilson29 is offline
post #8 of 22 Old 08-20-2012
Crazy Woman Boat Driver
Melrna's Avatar
Location: Heading south down the US east coast to the Bahamas
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Where can you buy the net?
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
post #9 of 22 Old 08-20-2012
Old as Dirt!
svHyLyte's Avatar
See (click on) Defender Safety Netting
FWIW...
svHyLyte is offline
post #10 of 22 Old 08-20-2012
Old as Dirt!
svHyLyte's Avatar
I elected not to use wire ties because of our locale (southwest Florida) where even black ties deteriorate and weaken quickly in the sun. They may be an option further north, however. Further, note that our daughter was always tethered when she went on deck--except when she wasn't. One can never tell when a child might manage to get on deck untethered, regardless of how watchful her/his parents are. It happens. The netting is a safety precaution, but not a substitute for vigilance. In re: bungie cord for the bottom of the netting, we found that it worked best if stretched such that it was fully extended when the mid-point between stanchions could be raised about 6" off the deck/toe-rail. That was enough to pass a line but not a kid/dog.
FWIW...
svHyLyte is offline
Securing safety netting nestorph Gear & Maintenance 3 08-09-2012 11:04 AM
Safety Netting and Jib Sheets dvuyxx Gear & Maintenance 5 03-12-2011 04:30 PM
Safety Netting on a Pearson 35 dvuyxx Pearson 1 04-26-2010 03:10 PM
Safety netting Jotun Gear & Maintenance 6 02-07-2007 07:47 PM
Safety netting for children prussell Cruising and Sailing with Children 8 05-17-2003 01:58 PM
