CS36 head intake vented loop - SailNet Community
post #1 of 6 Old 09-12-2013 Thread Starter
Hey guys, i've been re-doing all the head plumbing on my CS36 and noticed that there is not a vented loop on the head intake hose. There is for the discharge but not the intake. According to the CS36 manual that's how it came from the factory. It seems as if the intake/toilet is right at or just below the waterline, at least on port tack anyway. Has anyone else noticed this or added one? I have found the CS36 to be a very well designed and thought out boat and can only deduce there is probably a good reason why they didn't do this initially, but it goes against everything that i've read about proper head plumbing installations. Any comments?
thanks.
Nias is offline
post #2 of 6 Old 09-12-2013
Maine Sail's Avatar
Re: CS36 head intake vented loop
thanks.
The vented loop does not go in the intake it goes between the outlet of the pump and the back of the bowl. I had to re-plumb ours to make it right.
Factories do lots of STUPID things, even good builders like CS. Things like installing check valves on centrifugal/Rule type pumps, solid copper AC wire and siphon breaks on intakes among other stupid items.. These are all lack of RTFM events....
You will need to drill a few holes behind the head to route the hose to the siphon break, behind the medicine cabinet, and hoses between the back of the bowl and pump.
Not a tough job but one that should be corrected.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 6 Old 09-12-2013 Thread Starter
Hey Maine Sail, thanks, i had a feeling that might be the case. And thanks for pointing out that the siphon break should be between the pump and the back of the bowl. I missed that part reading peggy hall's book but went back and re-read it and now i understand why it's supposed to be there and not on the intake.
Nias is offline
post #4 of 6 Old 09-12-2013
jimrafford's Avatar
That's how my 36 was set up
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #5 of 6 Old 10-21-2013
serenespeed's Avatar
I'd like to hijack the thread back to Mainesail's comment about "installing check valves on centrifugal/Rule type pumps"...
I noticed a check valve, under the quarter-birth, for my centrifugal/Rule bilge pump on my CS36. I did not think anything about it. I assumed it was to stop back-flow from the almost deck level through-hull. Do centrifugal pumps stop back-flow on their own, by design? or?
Thanks.
serenespeed is offline
post #6 of 6 Old 10-27-2014
al brazzi
I found my CS30 set up the same way with the loop on the intake, with what looks like a bleeder in place of the check valve on the loop. I don't know what the thought was but if you could get to it (and you can't, its behind the cabinet) you could break the siphon manually I guess, maybe after plumbing they realized it wouldn't work and replaced the check with a bleeder. In any event the safety on my head anyway is the "pump dry" lever on the head pump. I was getting some leakage but it turned out to be the Joker valve, smelly too of course.
albrazzi is offline
Vented Loop for raw water to head. hriehl1 Gear & Maintenance 11 06-26-2013 08:37 PM
Head vented loop location turbulicity Gear & Maintenance 2 04-13-2011 04:55 PM
Vented Loop rjg23 Diesel 5 08-25-2010 11:33 PM
Is a vented loop between head and tank needed? jarcher Gear & Maintenance 5 06-02-2009 10:56 AM
Head and vented loop mroskothen Gear & Maintenance 4 07-10-2003 07:38 PM
HTML code is Off
