1977 CS 27 Engine Bed Stringers - SailNet Community
post #1 of 2 Old 08-31-2014 Thread Starter
The old YSB8 came out of our 1977 CS27 a while ago and we are hoping that someone has some specs for the engine bed stringers. It looks like lag bolts were used to attach the engine but without the original mounts for that engine available it is not clear how far down into the stringers one can screw without potentially causing some damage. We're not modifying the stringers so screwing into the original holes is the plan. A few questions:
1) Are these just galvanized lag bolts going into wood or was there some kind of nut that was used?
2) How far into the stringers can one safely screw? Inserting a toothpick into the original holes only seems to go in about an inch but I'm not sure if this is sufficient depth?
3) I think the original lag screws are 5/16". Would it make sense to use a 3/8" instead?
Any input would be greatly appreciated.
Thanks,
Owen
1977 CS27
oft2 is offline
post #2 of 2 Old 09-02-2014
jimrafford's Avatar
Re: 1977 CS 27 Engine Bed Stringers
I would suggest going to the "cs owners forum"
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Can a keel stub and stringers be repaired (hypothetical) deniseO30 Sailboat Design and Construction 3 07-18-2013 11:37 AM
1964 Columbia 26 metal stringers has cracks under the mast mickdj Introduce Yourself 1 11-06-2010 08:44 PM
stringers QuickMick Gear & Maintenance 1 05-18-2010 01:39 PM
BIG Stuctural Problem? (Hull Stringers pulling away) RichP Gear & Maintenance 24 07-22-2008 12:36 PM
Drilling holes through stringers. ceol Gear & Maintenance 13 09-07-2007 10:03 AM
HTML code is Off
