New CS30 - SailNet Community
 2Likes
post #1 of 11 Old 10-14-2014 Thread Starter
al brazzi
New CS30
I am currently getting to know my new CS30 1987 Model. Cleaning and repairing what is needed. I would like any info on how the vented loops are (properly) installed on the head and the Motor. I'm sure my Boat is not proper now. Also before I start looking are there typical leak points on the deck. I get fresh water during a rain, working into the cavity behind the switch panel. Then on top of the steering cover panel which has been wet for some time now judging from the delamination of the panel. Also while under way sailing in a breeze with water splashing on deck, in the compartments under the seats. Aside from these things she is in pretty good shape.
So far I like the boat and would appreciate any help.
albrazzi is offline
post #2 of 11 Old 10-30-2014
Re: New CS30
Sorry Albrazzi, my cs30 doesn't have any deck leaks. All I can suggest are the usual, stanchions, and chain plates. Possible hull deck joint, but that is sealed with butyl tape do as long as the bolts at the toe rail are reasonably tight there should be no leak. At the start of the season I usually go around the toe rail with a screwdriver making sure they are snug. The only other suggestions to check are the cockpit drain hoses. The ones on my boat where rotted, and every time the bat heeled it would fill with water. Also there is no anti-syphon valve between the head and holding tank, so if the head joker valve goes, the holding tank can back feed into the head. Good luck
chamonix is offline
post #3 of 11 Old 10-30-2014
Re: New CS30
Originally Posted by albrazzi View Post
..... I would like any info on how the vented loops are (properly) installed on the head and the Motor. I'm sure my Boat is not proper now. .........
Exhaust System Basics | West Marine
Installation Instructions for Jabsco Manual Marine Toilet
And a good discussion here (long thread)
I hate boats...
Faster is offline
post #4 of 11 Old 10-30-2014
Warm Weather Sailor
Vasco's Avatar
Re: New CS30
Do not tighten your toe rail this way. Tighten it by tightening the nut down below while someone holds a screwdriver on the bolt. If you try turning the bolt with screwdriver you'll only loosen the butyl tape that's on the bolt. Turn the nut not the bolt.
Faster likes this.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #5 of 11 Old 10-30-2014 Thread Starter
al brazzi
Re: New CS30
Faster,,Maybe the "Hate Boats" thing gets to the point later but I have never read so much useless dialog in my life. Not your suggestion just the thread.
I have read, I think, most all of the suggested diagrams and I just need to get past understanding how and why CS did some of the things they did.
For the leaks I just need to pull panels and hose the deck down, the interior headliners don't hold up well to water intrusion, the one under the cockpit is toast and a few more may not go back too well either.. No problem, its all work I can do I just need to get to it.
Thanks for all the replies, I will probably haul for the winter soon and add some stuffing box service to the list, shaft coupling is rusted BADLY and the hose on the stuffing box feels pretty soft to me its supposed to be 6 ply but I doubt it.
albrazzi is offline
post #6 of 11 Old 10-31-2014
CS Cruiser's Avatar
Dock
Re: New CS30
Hey enjoy your new CS30!
seabeau likes this.
Paul
s/v TENACITY - CS36T
CS Cruiser is offline
post #7 of 11 Old 11-03-2014 Thread Starter
al brazzi
Re: New CS30
Thanks Paul, and everyone else. It doesn't feel right putting it away after only a month in the water but I have time to get her right for the spring.
albrazzi is offline
post #8 of 11 Old 01-24-2015 Thread Starter
al brazzi
Re: New CS30
Found the leak(s) a screw attaching a block that the headliner screws to was run in too deep and through the hull deck joint up to the rub rail. It was leaking as far as I'm concerned since the boat was built from the condition of the panel underneath. When I pulled the screw it really leaked and tightening the hull deck fasteners squeezed some butyl in the hole and we're done. Bonding some blocks to the under side of the deck to attach the headliner blocks to and will use some shorter screws. The other one was in the binnacle hoop where the hoop screwed to the deck clip. I'm curious if anyone with a CS 30 has a dorade scoop on the emergency tiller deck plate I'm getting some rain water in through that too, not much of course but it could easily just be capped. Its a bad spot for a vent on a blue water boat but I'm not doing that kind of sailing.
albrazzi is offline
post #9 of 11 Old 10-12-2015 Thread Starter
al brazzi
Re: New CS30
First year went too fast. No deck leaks from repairs made. Made some nice rail seats for the cockpit and one for the bow rail, sweet.
Finally registered for the Thursday beer can regatta halfway through the season, need a new Main Maybe?? running gear has been flawless got the oil pressure alarm repaired, I like the horn. I made a heavy bracket for a shut-off valve for engine intake water and hang the ignition key from it so its closed unless the Motor is running, still don't completely trust what they were using as siphon protection on the engine water. Many interior details, made a floor grate for the head that looks phenomenal from some Bubinga I had laying around made a long drawer (22") that pulls out above the engine cover that provides needed fast access storage for flashlights hand tools etc. Added 4 speakers to the already rocking CD/Radio/Pandora setup, two 5x7 Polks on the panel under the cockpit floor in aft berth that had to be replaced anyway from a small water leak on the pedestal. Made a stove cover resembling the Teak and Holly sole. All in All a good year a few more good late season days on the water and tied up for the winter. Cabin sole and Boarding gate on the list now but not as many items as last year.
Oh and survived an almost Hurricane a couple of weeks ago.
Happy Sailing AL
albrazzi is offline
post #10 of 11 Old 12-02-2016 Thread Starter
al brazzi
Re: New CS30
Anyone out there have pictures and or suggestions on backstay adjusters and chainplate arrangement for this Boat. Im doing soon/now just need some guidance.
Thanks
albrazzi is offline
Beneteau First 285 vs CS30 Advantex Boat Review and Purchase Forum 0 08-18-2014 11:56 PM
CS30 Keel Corrosion StephenP CS Yachts 5 05-17-2013 11:59 AM
New to CS30 GordZ CS Yachts 10 03-03-2013 09:43 PM
Hatch Covers for CS30...? HBBurlington General Discussion (sailing related) 0 08-15-2011 02:32 PM
HTML code is Off
