Airmar P79 CS36T - SailNet Community
post #1 of 4 Old 04-27-2015 Thread Starter
Airmar P79 CS36T
Anybody have luck getting a shoot through the hull depth transducer such as Airmar P79 to work on a CS36T? I know the hull is actually fairly thick, maybe as much as 3/4"? which I believe is a little thicker than Airmar recommends. I am not getting a reading in any of the test areas I have tried, although I did not remove any paint or gelcoat yet in those test areas. The unit does work fine if I test it over the side in the water. If you got one to work where did you put it? Thanks.
Nias is offline
post #2 of 4 Old 04-27-2015
Re: Airmar P79 CS36T
Are you trying the waterbag trick? Fill a ziploc bag, seal it with no bubbles, put it against the hull and try placing the transducer on top of that.
Air in between the hull and transducer can cause problems.
Faster is offline
post #3 of 4 Old 04-27-2015
Maine Sail's Avatar
Forward starboard v-berth foot locker just behind the forward bulkhead in that locker. No issues.. I suggest testing it with a toilet bowl wax ring rather than a baggie full of water... I have one customer who stuck it in a wax ring for testing 12 years ago, and it is still there today. He lost the rest of the kit and has no desire to change what's working for him....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 4 Old 04-27-2015 Thread Starter
Thanks guys, I'll give those suggestions a shot. Was trying the vaseline test without results. Maine did you grind down the paint or gelcoat in the area you suggested? Do you think that is necessary? Starboard foot locker area is probably a good spot. I was trying the locker under the head sink.
Nias is offline
Airmar P79 troubleshouting Robchabot Gear & Maintenance 4 03-06-2015 10:58 AM
New to us CS36T and Westerbeke 30 novic Diesel 22 06-28-2014 12:37 AM
CS36T ports flysci CS Yachts 4 09-15-2013 11:50 PM
Change Airmar transducer spinwing Electronics 1 05-22-2010 07:30 PM
Going to see a CS36T PalmettoSailor CS Yachts 4 11-11-2008 12:17 PM
HTML code is Off
