Engine mounts - SailNet Community
post #1 of 2 Old 03-14-2017 Thread Starter
mutt's Avatar
Dock
Engine mounts
Hello all
My CS 36T has a Westerbeke W33 engine with a Velvet Drive series 1000 transmission and a Walter V Drive. I replaced the engine mounts because they were hard and the front engine mount was broken. What I think is unusual is that I have 5 engine mounts. One at the front, two at the rear of the engine and another two on flanges mounted to the V drive. Is this normal? 5 mounts make it difficult to align the engine. Do I need to two additional mounts?
Thank you for you help.
mutt is offline
post #2 of 2 Old 03-15-2017
Master Mariner
capta's Avatar
Re: Engine mounts
Our Onan has only three. The Perkins has two on the engine and two on the Borg Warner transmission.
If I remember correctly, you must align the V drive to the shaft first and then the engine to the V drive. There shouldn't be any problem as they are two separate operations.
facebook.com/svskippingstone
Our Videos;
capta is online now
Engine Mounts davidpm Gear & Maintenance 3 05-17-2012 08:19 AM
Engine mounts GaiaOrion Gear & Maintenance 6 06-05-2011 12:38 AM
Engine Mounts quanyin Pacific Seacraft 0 05-03-2011 12:00 PM
Engine Mounts winethief Gear & Maintenance 3 06-03-2009 04:41 PM
Need Engine mounts.. RDV Gear & Maintenance 2 09-05-2006 02:15 PM
HTML code is Off
