Blogs
Go Back   SailNet Community > Boat Builders Row > CS Yachts
User Name
Old 04-15-2008
bestfriend's Avatar
bestfriend bestfriend is offline
Hitchin' a ride
bestfriend is a jewel in the roughbestfriend is a jewel in the roughbestfriend is a jewel in the rough
CS34 engine hour meter install?
My CS34 does not have an engine hour meter, and I think, but am not certain, that most others did not come with one either. I tried hooking one up to the ignition in the cockpit and it worked, but, on my 34 there is another ignition switch down below in the aft cabin. Unless the one down below is turned off, the meter keeps running. So, how to install the meter at the Nav station and have it shut off when the ignition is shut off in the cockpit without having to go down and turn off the second switch. Anyone done this already?
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 04-15-2008
bestfriend's Avatar
Hitchin' a ride
My question was answered over on the CSOA site. Hook the meter up to the fuel pump switch. I'll post an update after I check it out.
Vaya con Dios
Old 04-26-2008
wbcj44 wbcj44 is offline
wbcj44 is on a distinguished road
Hour Meter Installiation
I have a Seafer 26' Sailboat. I want to install a hour meter. Does anyone know how? If so can I do it or do I have to have a pro come in and do it?
781 325 2444
Bill
Sponsored Ad
Old 04-26-2008
bestfriend's Avatar
Hitchin' a ride
This was another explanation and solution to my problem:
"Sound to me like you need to attach the positive to the ground outlet of
the ignition switch and the negative to the existing ground wire--put it in
series with the ground outlet. The problem is that you've got juice to the
positive terminal on the ignition switch all the time when the dc power switch is on,, and you only want the meter on when the current has gone through the ignition switch as is coming out the other end."
Vaya con Dios
Old 08-05-2008
alexco38 alexco38 is offline
alexco38 is on a distinguished road
Integrated tachometer with hour meter
I used a Teleflex tachometer with integral hour meter. No extra hook up necessary.
Display Modes
vB code is On
HTML code is Off
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
