Go Back   SailNet Community > Boat Builders Row > CS Yachts
  #21 (permalink)
Old 07-08-2009
ASA and PSIA Instructor
I think it is posted on CSOA, it is frequently asked for, search the posts.
  #22 (permalink)
Old 07-08-2009
JohnMaschek is on a distinguished road
Thanks, it was there and I down loaded. It really helps having the complete manual.
John Maschek
  #23 (permalink)
Old 07-16-2009
prior's Avatar
prior is on a distinguished road
ISOMAT 1982 CS Shroud cap
Hi John
I have a 82 cs36T. The spreader caps appear to be pressed and maybe flush rivited to the actual spreader. The shoulds are retained by a 1/4" ss special bolt and bushing which rotates. Mine were siezed and had to be carefully cut out. Then I replaced the bolt with a rubber bush, lanocote and covered the whoe thing with rigging tape due to the unreasonable cost of new spreader boots.
Also I used a rigging guage to check my tensions and found they were very low. I would imagine loose rigging would lead to the shroud coming adrift. Mine were held in place by the rigging tape only prior to the tension adjustment.
Paul
Three Rivers
  #24 (permalink)
Old 07-16-2009
prior's Avatar
Hi John
Paul
Three Rivers
  #25 (permalink)
Old 07-16-2009
RE-Attaching spreader to Mast CS36T 1982
Prior,
When I finally got up the mast, I found that the shroud was not in the retainer. My spreader is same as you described with the one screw and bushing holding the shroud in the groove. And yes, the screw was corroded in the spreader. Unfortunately, a PO has just taped the shroud in place as you described, also. I got the spreader off of the mast and repaired the siezed screw.
Now my problem is getting the spreader back on the mast. There ia a single pin that secures the spreader to the mast through a rubber bushing. Getting the pin to align through both sides of the spreader after it passes through the bushing is a real problem. The hole through the bushing is not aligned with with both holes in the spreader. I ordered new bushing from RIGRITE hoping the new one would better align since it was not worn, but no luck. This weekend I will drill out the bushing to get the pin through. Unless someone has done this before and knows THE TRICK.
Most of the CS boats are in climates that require storage during the winter. We are able to sail year round in north Texas - Good News and Bad News.
We never need to rig the mast off the boat. It would sure be easier. I hate heights, but not as much as paying a rigger to do it.
Thanks for all the good input. This site is invaluable.
John Maschek
S/V Some of its Magic
HTML code is Off
Mast, spreader, shroud design, help Talisman66 Gear & Maintenance 1 11-23-2008 03:41 AM
Damaged Shroud SEMIJim Gear & Maintenance 17 10-01-2007 01:44 AM
