Go Back   SailNet Community > Boat Builders Row > CS Yachts
  #11
Old 03-01-2012
chamonix is on a distinguished road
Not sure who your talking to but if it's to me in referance to the head problem, the head was filling from the holding tank not the through hall. Keeping the through hulls closed while sailing is excellent advice which I always follow.
  #12
Old 03-07-2012
HBBurlington is on a distinguished road
Re: CS30 Replacing the holding tank - poly or stainless???
Thank you to everyone who posted a response.
We are going to start with the hoses.
We are reasonably confident that they are original, (as is the tank), and likely the culprit for most of the malodorous atmosphere.
If we replace it, we'll go with the poly tank.
We have new cushions and upholstery being made for us, (Island Canvas...tell Abbey I sent you!), so it's paramount to me now that we get this addressed.
I am LOVING the boat.
This was important to my hubby, because it's not much fun if you are alone.
My first season as a sailor, and learnt much along the way.
Thanks to great neighbors on our dock, and my Sailnet colleagues, I feel much more confident about season 2.
Splash May 10th....BRING IT ON!!
Kim
Kim
Grand Illusion
  #13
Old 03-07-2012
Maine Sail's Avatar
Kim
Kim,
I currently have the tank out of our CS-36T (1979). Once the tank was cleaned, pressure tested and the clean out port re-welded, it was leaking around the spun welded fitting, the tank is 100% still perfect.
It exhibits ZERO odor. I simply sprayed the exterior with Lysol Bathroom Cleaner with bleach and let it dry. I then hit it a second time and finally rinsed the exterior. That was it.
There is zero odor on the tank exterior. My wife even stuck her nose to it and confirmed... I also filled it with 5 gallons of bleach and let it sit for two weeks then drained it. The tank now smells as good inside as it does out... Probably good for another 33 years.....
The hoses well they lasted about three years and all are odor permeated.......
______
-Maine Sail / CS-36T
  #14
Old 03-07-2012
Ah, the 36T.
We looked at one as well...a lovely beastie, but we thought the 30 was good for our starter boat.
Thank you for your advice.
To Oaksail:
We have the "Poop Tube", (as I call it) from Peter and plan to install it before we launch.
We only use the head for #1, so this is a bit of a misnomer, but you get my drift...
An upgrade would include a vacume flush system...maybe Santa will bring us one.
Kim
Kim
Grand Illusion
You may post attachments
You may edit your posts
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Replacing a Holding Tank Plywood Top wsmurdoch Pacific Seacraft 0 08-16-2009 01:00 PM
Adding a baffle to a poly diesel tank SailorByFate Gear & Maintenance 20 08-20-2008 02:44 AM
Poly holding tank pipe thread seal surftom Gear & Maintenance 9 06-23-2008 02:55 PM
Replacing Holding Tank ABullard Gear & Maintenance 1 08-15-2002 09:11 AM
SEO by vBSEO 3.6.1
