Go Back   SailNet Community > Boat Builders Row > CS Yachts
Old 07-16-2011
cptjak's Avatar
cptjak is on a distinguished road
CS 36T rudder shaft log
I noticed alot of green around my shaft log for my rudder, and was wondering if anyone knows what is in their for a water tight seal which mine does not have.
Old 08-29-2011
rugosa's Avatar
rugosa is on a distinguished road
The machined flange is glassed into hull near waterline level, if you drop the rudder you can repack it like a driveshaft log, should be in owner's manual, dropping rudder is overkill as there are adjustment bolts in the flange to allow you to tighten the packing (if it is leaking), if there is no adjustment left you should plan on pulling the rudder at your next haulout
HTML code is Off
Cat 27 rudder shaft bushings harl Catalina 2 04-02-2012 12:56 AM
Bent Rudder Shaft Oneablewilling Gear & Maintenance 1 07-18-2010 11:41 PM
Rudder Shaft Lube chs1517 Gear & Maintenance 4 11-15-2009 10:59 AM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 09:46 AM
Rudder Shaft Issues ranes Islander 0 11-03-2008 07:55 PM
