Cleaning the holding tank vent? - SailNet Community
post #1 of 3 Old 04-30-2012 Thread Starter
Question Cleaning the holding tank vent?
Hi,
Unless anyone can suggest an easier alternative...
I'd like to flush the line out with water from the opening port side, and clear any cobwebs/spiders/crawlies or otherwise that may be reducing the efficacy of that vent.
Or is there another way to clean this line out?
I doubt it has ever been done, and would like some suggestions.
Please and thanks in advance.
Only 11 more sleeps til we splash!!!!!
Kim
Kim
Grand Illusion
HBBurlington is offline
post #2 of 3 Old 04-30-2012
The most female moderator
Donna_F's Avatar
Dock
Re: Cleaning the holding tank vent?
Originally Posted by HBBurlington View Post
Hi,
Kim
I don't know if it was the best way, but that's what we did: disconnect it from the inside and send a blast of the water hose up through it. All kinds of gunk came out the other end onto the deck so it worked.
I don't know if it's typical, but on our boat the vent hose on the outside is inside a stanchion so it was easier doing it from the inside out.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 3 Old 04-30-2012 Thread Starter
Hi,
Thanks for the advice.!
Ours is located just below the deck on the port side, and really almost right below the bow pulpit.
The vent has a small button-like closure on it, so we may have to run the flush from the outside hanging over the deck and inwards down into the tank.
We have to pump out the antifreeze anyway, so anything that ends up in there will
be eliminated.
I guess it will also be a good way of finding out the line leaks, since the bilge will reveal
anything.
Ew...gunk....Can't wait.
K.
Kim
Grand Illusion
Holding Tank Vent tdw Gear & Maintenance 21 09-02-2010 10:32 PM
holding tank vent tugboatdon Gear & Maintenance 11 05-21-2010 12:39 PM
holding tank vent fitting Fitz87 Gear & Maintenance 12 05-10-2010 11:53 AM
Holding Tank Vent Filters jbondy Gear & Maintenance 14 02-12-2009 05:33 PM
Holding tank vent.. groundhog Gear & Maintenance 9 06-18-2007 08:37 PM
HTML code is Off
