Volvo Penta 2002 - Stalling and rough idle - HELP! - Page 2 - SailNet Community
post #11 of 13 Old 07-30-2012
Re: Volvo Penta 2002 - Stalling and rough idle - HELP!
Thanks for the updates, our engine is working fine, but this all adds to the knowledge base when we have problems.
chamonix is offline
post #12 of 13 Old 08-03-2012 Thread Starter
..........New racor on order now....bypassed the unit til it arrives, new fuel line from tank to engine, and can at least get out to grab some wind....once we're done the fuel system will be refitted.
Cheers,
Kim
Grand Illusion
HBBurlington is offline
post #13 of 13 Old 05-18-2015
We have a 2002 Four Winns 268 with a 5.7 carb Volvo Penta. We had the same type of issue. The mechanic said we had a corroded distributor cap, and wires, so he did a tune-up. Worked for a day and started doing the same thing. He then said it was water in the gas. He drained 60 gallons and filled the tank. It worked for a day. Finally I took it to another dealer and two of his mechanics took her for a sea trial. It turns out it was a loose wire on the high pressure side of the fuel pump. He repaired it and, $1500 in total, she has been running fine ever since.
bobjohn1212 is offline
Volvo Penta 2002 18 hp. after 5 to 30 minutes jtownsail Diesel 5 02-09-2015 07:44 AM
Volvo Penta 2002 engine gauge davidpm Gear & Maintenance 6 05-02-2012 08:22 PM
Volvo 2002 engine smeato Diesel 2 01-18-2012 05:00 AM
Volvo 2002 injector GerryC Diesel 3 12-20-2010 06:26 PM
Volvo Penta 2002 18 hp - turn key, Nothing! dwayne908 Diesel 17 08-30-2009 03:14 AM
HTML code is Off
