02-21-2010
I have to take exception to the remark that there is no difference between diesel and gas engines. Firstly, I have seen too many violent holes in the water with gassers being started without operating bilge blowers both fitted and operated for at least 10 minutes before starting. Also having an ingition system (read spark plugs and wires) gassers are not happy with even splashes of any water, raw or fresh. Except as noted in previous posts, most marine diesels once started need no electricity to run. Yes, injector systems are expensive but as long as you are religious with your filter maintainence will give long and trouble free service. Read the manufacturers instructions and keep them holy. Diesels rule....Cheers,Dumah, Halifax, NS
