08-30-2009
clueless
Originally Posted by witzgall
I am having issues with our 2002 as well! UGH. It is a really long story, but basically, I now have a remanufactured starter in place, but the only way we can start her is to attach the red wire that energizes the engine panel directly to the positive stud from the battery. Well, that worked for awhile,, but now, the starter either does not turn, or it will spin, not engage the motor, and continues to spin until we disconnect the battery.
The alternator is also not charging. I have removed that and am trying to find a place to test.
The original starter was removed when it would only start in the same way. So I am guessing it is not the starter? OR could both the "NEW" starter, and the old one, both have bad solenoids? Could this be a relay, or ???
Signed,
completely confused.
Chris
Ok...
First what is the voltage on the batts?? below 12.6 recharge them BEFORE you try to start the engine.. Your stater that is staying engaged is due to low volts and the amps are welding the contacts together! which will cause and over speed and the windings will fly apart " your re man starter is toast".
Next
if the starter excites when 12 volts is applied to the start post " the small gauge wire/post" the the problem is not in the starter but the wiring or the starter switch.
Try these and get back with me.
